A/V Furniture & Accessories
Crimson AV Robust Series TV Mounts
Crimson RST90 TV Mount
Crimson AV just released the Robust Series line of mounts designed for large format flat panel TVs. The Robust Series was developed to fill a void that currently exists in the marketplace and consists of three multi-joint models that accommodate 70 to 90-inch TVs weighing less than 200 pounds. RST90 is a tilt model, RSA90 is an articulating model, and RSF90 is a flat mount model. Lateral shift and post-installation leveling facilitates perfectly positioned TVs, while an integrated cable management system preserves design and decor aesthetics. Each model comes with a 400x400mm interface and is expandable to 400x600mm when the optional AD600 VESA Adapter is used. Priced competitively, the Robust Series mounts feature Crimson’s standard 30-day money back guarantee and industry-leading 10-year warranty, while carrying MSRPs starting at $215.
The Robust Series includes three models:
RST90 (pictured above)
Tilt mount with triple stud mounting that facilitates the most secure installation possible for heavier large-format 70 to 90″ TVs. Includes a horizontal slide mechanism that helps center the TV on the wall as well as post-installation leveling that compensates for uneven ceilings and enables a perfectly positioned TV. A unique all steel click-in-place feature simplifies the installation by eliminating the need to reach up behind the TV with a wrench or screwdriver to secure or remove it.
Crimson RSF90 TV Mount
RSF90
Flat mount with triple stud mounting that facilitates the most secure installation for heavier large-format 70 to 90″ TVs. Includes a horizontal slide mechanism that helps center the TV on the wall as well as post-installation leveling that compensates for uneven ceilings and enables a perfectly positioned TV. A unique all steel click-in-place feature simplifies the installation by eliminating the need to reach up behind the TV with a wrench or screwdriver to secure or remove it.
Crimson RSA90 Articulating TV Mount
RSA90
Articulating mount with a heavy-duty dual arm scissor action that provides better balance and smooth movement for large-format 70 to 90-inch TVs. Post-installation leveling compensates for uneven ceilings as well as the natural sag experienced with 100lb+ TVs. Lateral and vertical adjustments facilitate precision positioning and provide needed installation flexibility for recessed applications, and integrated cable management provides a clean look.
Manufacturing a broad assortment of professional grade AV mounting solutions and accessories for nearly any structure or application imaginable, Crimson products are ready to ship same day to integrators, distributors, systems designers and specifiers worldwide. Every product in the comprehensive assortment is manufactured to rigorous standards and sells for a fraction of the price of other competitive solutions, making it a highly compelling line that provides tangible benefits.
Price and Availability
RSF90 $215
RST90 $295
RSA90 $625
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
