Crestron Introduces New Occupancy Sensors
Crestron Green Light Expands its Energy Saving Product Line
ROCKLEIGH, NJ, January 26, 2009 — Crestron Green Light occupancy sensors are now available to enhance the functionality of Crestron Green Light environmental controls. The new Crestron occupancy sensors have built-in microprocessors and photocells to significantly reduce on-time for lights, cutting energy usage. Climate and device control can also be integrated. Models include wall and ceiling mount versions with a variety of coverage ranges.
Crestron Green Light sensors continually analyze and adjust to changing conditions, using the latest in microprocessor-based technology to optimize performance. Dual-technology (ultrasonic and passive infrared) sensing delivers optimum detection of motion while minimizing the effects of false triggers, such as electrical noise, air currents, and temperature changes. Passive infrared-only versions are available as well.
Upon activation, each sensor initiates in “walk-through” mode. “Walk-through” mode is active for a two and a half minute interval, during which lights turn off promptly when a person enters and exits the room. After the 2.5 minute period of occupancy, the sensor shifts into “occupied” mode.
“Delayed off” is initially set via the timer knob on the sensor, turning lights off when no motion is detected after a specific time. While the sensor is in use, the sensor learns room occupancy patterns. The delayed off time will change as the sensor intelligently adapts to environmental conditions and occupancy patterns.
When enabled, the built-in photocell overrides the occupancy sensor if the ambient light level is above a set threshold, preventing lights from turning on when there is sufficient daylight in the room. Sensor behavior can be customized via the Crestron control system.
New Crestron occupancy sensor models:
GLS-ODT-C-1000 Dual-technology ceiling mount, 1000 square foot range
GLS-ODT-C-2000 Dual-technology ceiling mount, 2000 square foot range
GLS-ODT-C-500 Dual-technology ceiling mount, 500 square foot range
GLS-ODT-W-1200 Dual-technology wall mount, 1200 square foot range
GLS-OIR-C-1500 Passive infrared ceiling mount, 1500 square foot range
GLS-OIR-C-450 Passive infrared ceiling mount, 450 square foot range
GLS-OIR-W-2500 Passive infrared wall mount, 2500 square foot range
For more information about the Crestron Green Light occupancy sensors go to www.crestron.com. For high-resolution photos go to www.crestron.com/pressroom.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
