Crestron MPC-M5 Media Presentation Controller
MPC Media Presentation Controller M5 Installs onto a Standard 2-Gang Box
The Crestron MPC family of AV room controllers delivers the most simple, cost-effective routing and control solution on the market today. Perfect for small classroom and meeting room applications, the 10-button MPC-M5 is now shipping. Featuring a built-in 2-Series control system, the MPC-M5 fits onto a standard 2-gang electrical box with space to accommodate all wiring and connections. Seamless integration with Crestron RoomView software via Ethernet enables IT/AV managers to remotely monitor, manage and control every room on the network, and SSL encryption provides a totally secure network connection at all times, preventing unauthorized access to the system.
According to Vin Bruno, Crestron Director of Marketing, “the M5 is the most affordable model in the MPC line, and with PoE (Power-over-Ethernet), it’s the simplest to install, requiring just one wire for operation.”
A fully-programmable user interface, the MPC-M5 is available in black or white, and features an attractive and intuitive layout of 10 pushbuttons with corresponding LED feedback, customizable backlit labeling, and wireless remote capability. It can be programmed for any function, including system power, input source selection, transport control, volume adjustment, and lighting presets. Like all MPC models, the MPC-M5 mounts in a wall or podium.
Through its onboard control ports, the MPC-M5 interfaces directly with the video display or projector, DVD player or TV receiver, projection screen, lift, occupancy sensor, and other room devices. In addition to high-speed Ethernet, there is a bidirectional RS-232 COM port, an IR/serial port, two relays, and two input ports right on the rear panel.
The MPC line is easy for instructors to learn and use, and equally important, can be implemented consistently in every room, lecture hall or auditorium. The MPC-M5 communicates directly with Crestron’s exclusive RoomView help desk software, the industry’s most comprehensive facility-wide solution for remote monitoring and asset management. Built-in SNMP support also enables integration with third-party network management software, allowing full control and monitoring from the IT Help Desk or NOC in a format that’s familiar to IT personnel.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
