Crestron Ceiling Mount Wireless Access Point Shipping
CEN-WAP-ABG-CM Provides 360 Degree Coverage with Power over Ethernet
CEN-WAP-ABG-CM
Now available, the Crestron CEN-WAP-ABG-CM Wireless Access Point (WAP) is the latest in a series of network, Power over Ethernet (PoE) solutions. The CEN-WAP-ABG-CM supports 802.11a/b/g Wi-Fi and enables easy setup, low profile ceiling mount installation, 360 degree coverage, and enterprise level security and management capabilities.
The CEN-WAP-ABG is powered right through LAN wiring, so there is no need for an adjacent electrical outlet. Installation is clean and simple: the CEN-WAP-ABG-CM mounts into a flat ceiling surface using a standard 1-gang plaster ring or wall box; its white color blends nicely with a typical ceiling, or its cover can be removed and painted.
Connecting wireless devices to the control network is quick and easy, and does not require configuration. Each unit ships with a unique network name and key. Simply enter the information in the touchpanel upon setup and the connection is instantaneous. Network devices connected to the CEN-WAP are totally secure. It supports up to 152-bit WEP encryption as well as the more advanced WPA and WPA2 authentication and encryption methods for a safe, secure wireless network in the home or office.
About Crestron
For nearly 40 years Crestron has been the world’s leading manufacturer of advanced control and automation systems, innovating technology and reinventing the way people live and work. Offering integrated solutions to control audio, video, computer, IP and environmental systems, Crestron streamlines technology, improving the quality of life for people in corporate boardrooms, conference rooms, classrooms, auditoriums, and in their homes. Crestron’s leadership stems from its dedicated people who are committed to providing the best products, programs and services in the industry.
In addition to its World Headquarters in Rockleigh, New Jersey, Crestron has sales and support offices throughout the U.S., Canada, Europe, Asia, Latin America and Australia.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
