Creek Audio’s 4040 A Integrated Amplifier Celebrates the Past While Looking Forward
The Creek Audio 4004 A Integrated Amplifier celebrates 40 years of audio engineering success while looking forward into the future.
Creek Audio 4040 A Integrated Amplifier Front
Creek Audio has been in the fight for 40 years and when it launched its first amplifier, the £99 Creek CAS4040 back in 1982, it created quite a stir. Mike Creek started his quest almost a decade earlier, and has managed in a rather understated way to offer some of the best affordable integrated amplifiers and phono preamplifiers available.
The brand has not been aggressive on social media which has kept it out of the spotlight, but that doesn’t negate the inherent value present in all of its products; Mike Creek builds really solid audio components. You would be hard pressed to find those within the industry who will dispute that; some of us wish that he would be more forthcoming with review samples but we’re working on that aspect of the story.
2022 ends with a blast from the past in the form of the new Creek Audio 4040 A Integrated Amplifier. The 4040 A is a rather compact integrated amplifier with streaming capabilities thanks to support for Bluetooth aptX HD and a myriad of digital inputs for network and CD players.
The Creek 4040 A also offers support for MM and high-output MC carts with an optional plug-in board.
Creek Audio 4040 A Integrated Amplifier Rear
Features
Control: The 4040 A’s intuitive user interface and the sophisticated menu system is easily navigated either by remote control or rotary control knobs.
Pre-Amplifier: The “Feature Rich” 4040 A contains three analog signal inputs, including two pairs of unbalanced RCA sockets and one pair of fully balanced XLR sockets. The electronic volume control enables precise 1dB adjustment over a 70dB range. Left/right balance, tone controls and EQ settings, further enhance its flexibility.
Phono: Compatible with an optional plug-in Sequel mk4 Phono Pre-amp in place of Aux 2 to match a wide range of Moving Magnet and high-output Moving Coil cartridges.
Headphone Amp: A dedicated headphone amplifier will drive a wide range of headphones via a front panel-mounted jack socket.
Digital Inputs: USB, coax SPDIF, optical Toslink, USB class 2 and aptX Bluetooth 5.0 increase the flexibility of this amplifier.
DAC: The 4040 A leverages the power of a premier grade ES9023 Sabre DAC to convert digital signals into analogue.
Power Amplifier: The 4040A employs cutting-edge MERUS™ technology to enable it to drive even the most difficult loads to realistic listening levels with high fidelity.
Power Supply: The key to the 4040A integrated amplifier’s impressive performance is in its high-frequency power supply, optimised for audio electronics, enabling the latent quality of its amplifier to be realized. The 4040A’s performance is unaffected by mains quality or voltage stability.
Unlike most conventional amplifiers, its 250-Watt power supply is voltage stabilized, enabling it to double its power output each time the load impedance is halved, regardless of the mains voltage.
Energy Savings: Signal sensing enables the 4040 A to reduce power consumption by powering down non-essential circuitry when not required.
Creek Audio 4040 A Integrated Amplifier Inside
Specifications:
  • Power output: 35 W into 8 Ohms, 70 W into 4 Ohms, both channels driven
  • Continuous max output current: >8A, current limited
  • THD and Noise: <0.01%
  • Signal to Noise Ratio: 102dBA Aux input, loaded
  • Frequency Response: 1Hz to 50 kHz, +/-3dB
  • Input sensitivity: 400mV for 35W into 8 Ohms, Aux 1 and 2 inputs
  • Crosstalk: >100dB at 1 kHz
  • Pre-Amp Inputs: 2x RCA (unbalanced) and 1x XLR (balanced)
  • Plug-in Phono options: Aux 2 changes to Phono with a Sequel mk4 MM Phono fitted
  • Digital inputs: 1x coaxial, 1x optical, 1x USB 2.0 PCM & DSD, Bluetooth aptX HD
  • Digital to Analogue Converter: ES9023 Sabre premier stereo DAC
  • Loudspeaker Outputs: 4mm binding posts with rear and side entry, plus a spade lug
  • Speaker output impedance: <0.02 Ohms 20Hz to 20 kHz. Damping factor >400 into 8 Ohms
  • Headphone Output socket: 6.3mm stereo jack socket for 30 – 300 Ohm headphones
  • Mains input voltage range: 100V to 240V nominal, 50Hz or 60Hz (automatic multi-region)
  • Fuse: Built into the power supply and not user serviceable.
  • Power Consumption: 5W, 250W, <0.5W – Idle, Max, Standby
  • Auto Standby: The amp will switch off automatically after an adjustable pre-set time, with no signal, or standby can be defeated in Menu.
  • Finish colours: Optional silver or black front panel. Black outer cover only
  • Weight: 2kgs (4.4 lbs) net, 3kgs (6.6 lbs) gross (packed)
  • Size W/H/D: 21.5 x 6 x 25.5 cm (17 x 3 x 13.8”) including feet, knobs, LS terminals and BT antenna.
Price & Availability [Update]
We’ve just learned the Creek Audio 4040 A is expected to sell for $1,200 USD in the U.S. and £800 in the UK.  Due to problems in China and the forthcoming Chinese New Year holiday, production will not start until February/March 2023. The USA importer is Matterhorn Audio. You’ll want to check with them for a dealer near you.
For more information: Creek Audio 4040 A Integrated Amplifier
Related Reading:
5 Comments
5 Comments
  1. Holygeezer
    December 11, 2022 at 8:37 pm
    The dimensions listed do not make sense to me. I noticed that they are the same on the Creek website. Assuming the 3 inch height is correct, it would seem by just looking at the front that it can’t be much more than 12 inches wide. Something seems amiss to me. Any thoughts?
    • Ian White
      December 11, 2022 at 10:13 pm
      It is a very narrow piece and I also raised an eyebrow when I saw the image on the website.
      I’m following up with Mike Creek for some info.
      Best,
      Ian White
    • Holygeezer
      December 14, 2022 at 7:44 pm
      I heard back from Mike Creek. The dimensions are: 8.46″ x 2.36″ x 10″ WxHxD
  2. Chris0905
    December 14, 2022 at 5:36 pm
    Looks like a bit of competition for the Rega io but with more bells and whistles.
    So what’s the price ?
    • Brian Mitchell
      December 14, 2022 at 7:20 pm
      Story just updated. UK/USA pricing is £800 / $1200.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
We've been listening to a lot of integrated amplifiers over the past 12 months, and these 4 are some of the best below $3,000.
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
Cambridge Audio introduces the EXA100 stereo integrated amplifier for $2,199 and the EXN100 Network Music Streamer for $1,799.
