Creative Labs’ Pebble Wireless Speaker Series Expands With the Nova
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
Creative Pebble Nova Desktop Speakers Black Front
Creative Labs has expanded its popular Pebble wireless speaker series with the Nova.
With its angled design and solid audio performance, the Pebble series has a loyal following. The Pebble Nova builds on this success, featuring an elegant design and audio quality that sounds better than its $279.99 price point would indicate.
The Pebble Nova is designed to deliver great audio, but it also functions as a centerpiece for small spaces. With the implementation of coaxial speaker drivers, the Pebble Nova aligns the tweeter and woofer in a single housing to support even sound reproduction across the entire frequency range.
For a better listening experience, the Pebble Nova can be paired with the Creative Sound Blaster X5 (Regular Price: $279.99) external DAC/USB Soundcard/Headphone Amp.
The Pebble family’s 45° elevated drivers work to accurately direct sound to the user’s ears, creating a personal and immersive listening experience. With the included stand, users can elevate the speakers for better audio projection and a sleeker look.
Creative Pebble Nova Desktop Speakers Exploded
The Nova also has RGB lighting that displays a wide range of colors that can spice up any party or social occasion.
Connectivity options include Bluetooth 5.3, USB, and a 3.5mm AUX input.
With the Creative App (Android, iOS), listeners can access Creative’s proprietary Acoustic Engine audio technologies, such as Surround, Smart Volume, Bass, Dialog+, and Crystal Voice, enabling users to fully customize audio settings and RGB lighting to suit their individual preferences.
Creative Pebble Nova Desktop Speakers - Creative App on PC
From Song Siow Hui, CEO of Creative Labs: “The Pebble Nova embodies our commitment to enhancing the audio experience for users who demand quality and style. It’s not just another product; it represents the next step in the evolution of the Pebble family,
Comparison
Here is a comparison between the Pebble Nova and the Pebble X Speakers
Creative Pebble Nova vs Pebble X Speakers
Pebble NovaPebble X
Price$279.99$89.99
Product Type Desktop Bluetooth SpeakersDesktop Bluetooth Speakers
Speaker Configuration2.0 system2.0 system
Wireless ConnectionBluetoothBluetooth
Wired ConnectionPD Adapter, 3.5 mm AUX-in, USB Audio (Type C)Mic-in, USB Audio, PD Adapter (Min. 30W), 3.5 mm AUX-in, USB Power (USB-C, up to 5V 3A)
Drivers Configuration1 x 3” driver and 1 x 1” tweeter per speaker arranged in a coaxial layout with a 1 x Passive Radiator per speakerDual 2.75″ Full Range Speaker Drivers
Frequency Response55–20,000Hz60–20,000Hz
Signal-to-noise ratio (SNR)≥ 93 dBNot Indicated
Power Output2 x 25W RMS, Peak Power: 100WWhen connected to PC USB-C port: Up to 15W RMS and 30W Peak*
When connected to USB-PD Power Adapter: Up to 30W RMS and 60W Peak**
Support for USB-PD 3.0
* When plugged into a PC USB-C Port** With USB PD Adapter, rated at 30W or higher (not Included)
Supporting TechnologiesSurround, Smart Volume, Bass, Dialog+, and Crystal Voice via the Creative app on a  PC.Sound Blaster Acoustic Engine, BassFlex, EQ, Dialog+ Controls
Bluetooth® Version5.35.3
Bluetooth Profiles(A2DP) Advanced Audio Distribution ProfileA2DP (Advanced Audio Distribution Profile)
Bluetooth CodecsSBCSBC
Bluetooth Operating Frequency2402–2480MHz2402–2480MHz
Bluetooth Operating RangeUp to 10m / 33 ft*, *Measured in open space. Walls and structures may affect the range of the device.Up to 10m / 33 ft*, *Measured in open space. Walls and structures may affect the range of the device.
RGB LightsUp to 16.8 million colorsUp to 16.8 million colors
Supported PlatformsWindows PC, Mac, PS5, Nintendo Switch, Mobile (via Bluetooth®), PS4Windows PC, Mac, PS5, Nintendo Switch, Mobile (via Bluetooth®), PS4
System Requirements (Windows)Intel i3 or AMD equivalent processor
Intel, AMD or 100% compatible motherboard
Microsoft Windows 11, Windows 10 32/64 bit ver 1903 or higher
> 4GB RAM
> 4GB of free hard disk space
Available USB C port for audio
> 4GB RAM
System Requirements (MacIntosh)Macintosh running MacOS 10.15 or higher
> 4GB RAM, > 4GB of free hard disk space
Available USB C port for Audio
System Requirements (PS4/PS5)Firmware Ver 5.0 or later for PS4 Firmware Version 20.02-2.26.00.00-00.00.00.0.1 or later for PS5Available USB C port for audioFirmware Ver 5.0 or later for PS4PS4 Firmware Version 20.02-2.26.00.00-00.00.00.0.1 or later for PS5Available USB C port for audio
Nintendo SwitchSwitch OS 5.0 or later
Other DevicesAvailable Line Out, Bluetooth for audioBluetooth for audio
Charging Type USB PD Input (Power Only): 65W, USB-C PD Power Adapter (included)USB-C Input (Audio and Power): Up to 5V 3A, USB PD Input (Power Only): Up to 15V 2A
Operating Temperature 0—45°C0—45°C
ColorBlack, WhiteBlack
Dimensions (Each Speaker)149.2 x 150.8 x 153 mm
5.87 x 5.9 x 6.02 inches
139.5 x 132 x 136 mm
5.49 x 5.2 x 5.35 inches
Weight (Each Speaker)1.89 kg
(4 lbs 3 oz)
600g
(1 lbs 5oz)
Package Contents1 x Creative Pebble Nova
2 x USB-C to USB-C Data/Power Cable 1.5m
1 x 3.5mm AUX-in Cable 1.2m
2 x Detachable Base and Stand
1 x 65W PD Power Adapter (Single USB C Port)
1 x Quick Start Leaflet
1 x Creative Pebble X
2 x USB-C to USB-C Cable
1 x 3.5 mm AUX Input Cable
1 x Quick Start Guide
Warranty 1-year
Limited Hardware Warranty
Check out a complete comparison of the entire Creative Pebble Speaker Line.
Creative Pebble Nova Desktop Speakers White
Creative Pebble Nova Desktop Speakers in White
The Bottom Line
Creative has a reputation for making innovative audio products that don’t carry a high price tag. The most recent of which are the Creative Aurvana Ace & Ace 2 Wireless Earbuds we’ve reviewed.
The new Pebbles Nova Bluetooth desktop speakers appear to be another product with a low price tag that packs in some practical features designed to complement PCs and Mac setups, as well as being connected and paired with other audio components.
Although it does have Bluetooth and physical connectivity, the Nova is not as comprehensive (no Wi-Fi or aptX HD) as some other desktop speakers from companies such as KEF or Audioengine.
Pricing & Availability
The Creative Pebble Nova is priced at $279.99 (USD) and is available at Creative.com
Related Reading
Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Totem Tribe Tower Thunderbird Speakers Drivers Close-Up Totem Tribe Tower Thunderbird Speakers Drivers Close-Up
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Vertere DG-X Turntable Red Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
The Atelier program gives Bang & Olufsen's customers the chance to style their own speakers. The Beosound 2 Gradient Collection gets things started.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Audio Pro can add more style to your home entertainment system with new walnut finish on its A28 wireless speaker at $650 pair.
Just add in-ceiling speakers to Q Acoustics 300A Ceiling Amplifier to bring streaming music and Amazon Alexa into any room.
At $599/pair, the Totem Acoustic KIN ONE bookshelf speakers promise performance far beyond its size and price.
Priced from $7,559, Sun Audio extends its Purified 4 modular speaker concept to the desktop with an all-in-one system.
At $299/pair, the FiiO SP3 HiFi Desktop Active Speakers pack a punch for their size, and include a stand and LED lighting.
