How to convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD.VOB ?
This step-by-step guide will teach you how to convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD(*.VOB) with this QuickTime M4V converter. The best QuickTime M4V converter with the features of QuickTime M4V to MPEG converter, QuickTime M4V to AVI converter and QuickTime M4V to DVD(*.VOB) converter, can help you convert QuickTime MOV, QT, MP4, M4V files to AVI, DivX, Xvid, MPEG1, MPEG2, VCD, SVCD, DVD(*.VOB) files.
Introduction of this QuickTime M4V converter
This QuickTime M4V converter is a QuickTime M4V to AVI, QuickTime M4V to DVD(*.VOB) and QuickTime M4V to MPEG converter to convert QuickTime M4V to MPEG, convert QuickTime M4V to AVI. The QuickTime Converter can help you convert QuickTime MOV, QT, MP4, M4V files to AVI, DivX, Xvid, MPEG1, MPEG2, VCD, SVCD, DVD(*.VOB) files.
With the fast and powerful QuickTime video decoder inside, Ultra QuickTime Converter can support almost all MOV, QT, MP4, M4V files, even QuickTime Player has not been installed.
The main features include:
Batch convert MOV, QT, MP4, M4V files to various format files;
NTSC/PAL setting options for DVD, VCD, SVCD exporting;
Change the video bitrate, audio bitrate, framerate, image size etc as you like.
Very user-friendly interface and easy to use.
Very quick in conversion speed and no quality is lost!
Key Features:
Supports MOV, QT, MP4, M4V formats to AVI, DivX, Xvid Supports MOV, QT, MP4, M4V formats to MPEG1, MPEG2
Supports MOV, QT, MP4, M4V formats to VCD,SVCD,DVD(PAL,NTSC)
Do not need install QuickTime Playerr
Multi-task batch execute function
Supports Drag and Drop quciktime files from Windows Explorer
Support large video file, even large then 2GB
Very fast and without any quality loss
Very User-friendly interface
Step-by-step Guide:How to convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD(*.VOB) with this QuickTime M4V converter?(Take converting QuickTime M4V to AVI for example)
Step 1: Free download this QuickTime M4V converter from http://www.sharewareguide.net/downloadit.php?pd_id=3707 and save it in your computer, and then run it.
Step 2: Launch this QuickTime M4V converter and you will find the user interface simple and easy-to-use.
Step 3: Click “Add Files” button to select QuickTime M4V file as input file.
Step 4: Click “Change” button to select a path for the AVI outputed file, Or you can don’t take any operation and use the default path.
Step 5: Click “Output Format” combo-box to select AVI as the outputed file.
Step 6: Click “Convert” button to start to convert QuickTime M4V to AVI.
OK. You successfully compelete to convert QuickTime M4V file to AVI with the QuickTime M4V converter.
I use this powerful and professional QuickTime M4V converter to convert QuickTime M4V file to AVI with perfect quality and fast speed. And we can convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD(*.VOB) and convert all QuickTime files MOV, QT, MP4, M4V files to AVI, DivX, Xvid, MPEG1, MPEG2, VCD, SVCD, DVD(*.VOB) files. I like this software and would like to share it with you.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
