Compact Preamplifier Produces Big Results
Santa Clara, CA – September 14, 2007 — Pragmatic Communication Systems, Inc., an industry innovator in wired and wireless systems since 1994, recently announced another of its successes: the Preamplifier 9, a fixed gain, low noise, high dynamic range, and high signal-to-noise ratio preamplifier.
The Preamplifier 9 is another advancement in Pragmatic’s HideAway Series of audio components, which offer the most compact and efficient designs. The miniature yet powerful preamplifier delivers high quality performance at an affordable price.
Much of the music people listen to today come from computer sound card outputs, portable CD players, MP3 players, satellite radio receivers, and others sources. These modern audio sources have very low-level audio output, which is insufficient in order to produce normal audio outputs from most amplifiers. The Preamplifier 9 offers a fixed gain block between the sources with extremely low noise and very little distortion. In addition, it produces unexpected sound depth and musical clarity.
The unit accepts a line level signal on a 3.5 mm stereo input jack and provides an amplified signal on a 3.5 mm stereo output jack. The standard units are available with 8.1 dB gain and custom configurations are available with any desired gain up to 36 dB.
Pragmatic continues its mission to produce environmentally friendly products by designing the Preamplifier 9 to operate on a low power 7.5 V DC. It also fits inside a trim 2.5″ W x 1.65″ H x .85″ D box and weighs an impressive 1.23 ounces. Many assume that in order to make the product small and efficient they must sacrifice on performance quality, but the Preamplifier 9 dispels that belief with its ability to perform just as well or better than its larger competitors.
Pragmatic Communications Systems, Inc. is a Silicon Valley based company established in 1994 to design, develop and produce a variety of innovative and environmentally conscious products for wireless audio, video and data communications. The majority of the company’s products up until 1997 were designed for industrial and commercial applications, after which Pragmatic branched into the consumer market. The success of the older products led to a strong and dynamic technology base, which helps fulfill Pragmatic’s mission to create solutions to long unresolved technical problems with designs that are both compact and energy efficient. This belief has been applied to a new generation of Pragmatic products such as PADS, DMS, DAVES, CATS, True Music wireless hi-fi system, and True View wireless video system.
More information on the products mentioned here can be found on the Pragmatic website at http://www.pragmatic1.com
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
