Headphones
Coloud Relaunches with Budget Headphones under $40
Coloud Headphones 2016
Coloud Headphones, a brand under Zound Industries, the parent company of Urbanears and Marshall Headphones, will officially relaunch and announce its new lineup, consisting of two on-ear headphone models, No. 8 and No. 16, and one earbud model, No. 4.
Coloud emphasized on great design and lightweight, durable construction to ensure these headphones keep up with the lifestyle of active youths. Coloud prides itself on providing a dynamic sound experience, with all the useful features you need, and without the stuff you don’t.
Coloud No 16
No. 16  ($39.95)
No. 16 is a tough and flexible headphone designed to deliver your daily dose of music while withstanding the pressures of daily listening. Featuring a durable construction and ultra-flexible, cushioned headband, No. 16 helps you roll with the punches without giving up your soundtrack. Pick up calls easy with a built-in mic and remote. When it’s time to pack things up, built-in hinges fold up and snap into place for easy portability.
Coloud No 8
No. 8 ($29.95)
Sleek and strong, No. 8 is an ultra-lightweight pair of headphones designed to withstand the pressures of everyday listening. No. 8 has all the practical details covered, featuring a tangle-free cable with mic and remote, and a ZoundLasso for tidy storage. Add 3-D ergonomic design, and you’ve got the perfect fit and non-stop comfort.
Coloud No 4
No. 4 ($19.95)
The No. 4 is a highly durable pair of earbuds that knows how to power up the sound. Angled earbuds and multi-sized replacement caps give the perfect in-ear fit, delivering direct sound and a powerful bass. No. 4 helps keep everything in place with a tangle-free cord with clip, and magnetized earbuds that snap together around your neck.
These join other key players from the Coloud range, including headphones The Hoop and The Boom Kids, and portable speaker The Bang.
The new Coloud collection is now available in select stores and online at coloud.com.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
