ClearView Audio Clio Wireless Speaker
ClearView Audio Clio Speaker
Clio, by ClearView Audio, is a revolutionary new wireless speaker that uses an ultra-thin, slightly curved, and optically clear acrylic glass transducer to disperse sound waves in multiple directions. Because of its innovative acoustic design, Clio can be placed anywhere and produce rich, clear, room-filling sound. Clio’s sleek, minimalistic design allows the barely visible speaker to “disappear” against its surroundings.
ClearView Audio has developed Edge Motion, a breakthrough patented technology that creates high quality audio from an optically clear speaker. This technology uses a very different mechanical principle to generate sound. Instead of pushing from behind, like a traditional cone speaker, Edge Motion-driven speakers use piezo-electric actuators to stimulate the sides of an optically clear acrylic glass stereo transducer to produce an extremely efficient, piston-like motion. The result is a thin, lightweight and invisible transducer that produces rich, full sound across the audio range.
The invisible wireless speaker is named after one of the nine goddesses of music, song and dance, Clio. The speaker connects to just about any Bluetooth enabled smartphone or tablet to stream your music to it. Unlike traditional cone speakers that push sound waves in one direction, Clio produces stereo sound from both sides of the speaker, offering a 360° sound experience.
https://www.youtube.com/watch?v=a-wZlUsO1VQ
Price and Availability
The Clio will start shipping November 17, 2014 for $349 in three colors options: silver, dark bronze or charcoal. It will also be available at Restoration Hardware stores across the U.S. and Canada, and at rh.com.
Features
  • Clear 1mm-thick acrylic panel delivers 360-degree stereo sound
  • Superb long-range sound clarity and fidelity
  • Pairs with up to 16 Mac and Android devices
  • Compatible for streaming with Bluetooth 2.1 and 4.0 devices
  • Supports enhanced data rate (EDR) and advanced audio distribution profile (A2DP) 1.2
  • Optional 3.5mm audio input
  • Edge Motion technology with proprietary left- and right-channel piezoelectric actuators
  • Proprietary down-firing 2″ woofer
  • 33-foot wireless range
  • Comes with AC adapter, power cable, 3.5mm audio cable, microfiber cleaning cloth
Dimensions
  • Height: 9-1/4″ / 23.5 cm | Width: 12-5/8″ / 32.1 cm | Depth: 3-3/4″ / 9.5 cm
  • Clear Transducer Thickness: 0.04 inches / 1.0 millimeter
  • Weight: 1 lb. 15 oz. / 0.88 kg
  • Shipping Weight: 4 lbs. 2 oz. / 1.87 kg
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
