Classe Audio Brings DVD Player to Acclaimed Delta Series
Montreal, Canada- June 2005–Classe Audio, the Quebec, Canada manufacturer whose standard-setting components for high-end audio and home-theater systems are admired worldwide, has enhanced its acclaimed Delta series of refined audio-video components with a superb new DVD player. In addition to DVD-Video discs, the Classe CDP-300also plays DVD-Audio, standard CDs, DualDisc, and discs encoded with MP3, WMA and AAC audio formats. The newest Classe also handles Video-CD, S-VCD and JPEG picture discs.
Fashion, Function and Firsts
As the first Classe Delta series DVD player, the CDP-300 shares the beautiful industrial design and elegant control screens found throughout the range. It is in fact the first DVD Player to offer touchscreen control and video preview on the front panel. The preview feature allows audiophiles the option of enjoying a pure music listening session without the noise often associated with projectors and other display devices. Simply navigate DVD-Audio (or DVD-Video) discs from the front panel and listen under quiet, ideal conditions.
The CDP-300 DVD Player utilizes a slot-loader mechanism for reading discs. It was chosen for its superior disc-handling characteristics, reliability and control options. Fitting neatly within the delta series model’s black control strip, the slot is illuminated by a soft blue light to assist when loading discs in a darkened room.
From its specially designed, vibration-absorbing feet to its strong and rigid chassis and DVD-ROM drive, the CDP-300 is a “from the ground-up” design, serving as a high-quality and reliable disc-playing platform with audio and video signal paths fully optimized to deliver the experience like no other.
Digital to Analog, Amazing Audio
The presence of jitter (time base distortion) at the point of conversion from digital to analog increases distortion and robs the playback system of resolution. To reduce jitter in the CDP-300, digital audio signals of all types (CD, DVD, DVD-Audio, etc.) are routed through a CPLD (Complex Programmable Logic Device) and sample rate converter to de-correlate them from the MPEG decoder (video) clock. The result is that all digital sources are recreated as 24-bit/192kHz signals and re-clocked before being output to the D-to-A converters. By attacking jitter at its source, the Classe Design Team makes great sounding audio possible from a variety of digital formats.
Three stereo DACs (with 8x filters) have been selected to perform the delicate process of converting digital audio to analog. Each channel of each stereo DAC is itself converted as a differential signal. Six channels of analog audio are output in single-ended format on RCA connectors, while the front left and right channels are also available balanced on XLR connectors. These channels are truly balanced, having been taken as differential outputs from each channel of a stereo DAC.
Digital and Analog, Virtuous Video
The latest flat panel displays and certain projector models can display as many as 1080 horizontal lines at once. In order to capitalize on this new, higher resolution capability, the CDP-300 DVD Player utilizes newly developed video processing circuitry, making it the world’s first DVD player to offer a full implementation of all HDTV resolutions. Digital video on HDMI is available at 480i, 480p, 576i, 576p, 720p, 1080i and 1080p.
In addition to deinterlacing and scaling functions, the CDP-300 employs extensive digital processing to reduce “mosquito noise,” improve edge definition, adaptively control color/contrast ratios and improve chroma transient performance. Said another way, the CDP-300 performs complex mathematics to deliver a sharper, clearer, more compelling image than has been possible from earlier DVD player technologies.
Encore!
As with audio, the performance of video circuitry owes partly to the individual components and partly to the execution of an overall design strategy. The fact is, high-end players often use similar parts, but usually reach quite different levels of performance. The CDP-300 uses state-of-the-art component parts, employed to maximum advantage and built with precision and care. But its true value is only realized by playing familiar music recordings and watching your favorite movies.
First to market with 1080p video, first with touchscreen control and first with video preview capability, the CDP-300 is truly in a class by itself because of its subjective audio and video performancequalities. The subjective experience is what separates a Classe disc player from everything else.
CDP-300 Highlights
Audio
· Compatible with CD, DVD-Video, DVD-Audio, DualDisc, Video-CD, S-VCD, MP3, AAC and WMA formats.
· All audio formats are up-sampled to 24-bit/192kHz prior to Digital-to-Analog conversion.
· Classe Audio’s Re-clocking circuit topology effectively attenuates clock jitter mechanisms that are present in most other DVD playback solutions.
· All audio formats are decoded internally before Digital-to-Analog conversion. A concurrent IEC958 (SPDIF, AES/EBU and TOSLINK) output is provided.
· DVD-Audio is output as IEC958 (SPDIF, AES/EBU and TOSLINK) for decoding in a Surround Sound Processor with a concurrent 2-channel analog audio downmix.
· 6 analog audio outputs are provided with RCA connections (single-ended). Front Left and Right outputs are also supported in balanced format.
· Audio and video are synchronized during DVD-Video playback.
Video
· Worlds first high-end DVD Player to offer a full implementation of all HDTV resolutions.
· Digital Video output on HDMI can be de-interlaced and scaled to the following resolutions: 480i, 480p, 576i, 576p, 720p, 1080i and 1080p.
· Analogue Video output on YPrPb/RGB can be de-interlaced and scaled to the following resolutions: 480i, 480p, 576i, 576p, 720p and 1080i.
· Extensive digital video processing to reduce video “mosquito” noise, improve edge definition, adaptively control color/contrast ratios and improve chroma transient performance.
Control
· Touchscreen user interface with video preview mode
· Bi-Directional RS-232 Control
· CAN BUS ports for inter-Classe component communication
· Rear panel IR and DC trigger sockets
· IR Remote control with backlight and Classe system Function Keys.
The Classe CDP-300 is manufactured entirely by Classe at its Quebec facilities, using the highest-quality components available worldwide. Its striking aluminum chassis, fascia and touchscreen front panel combine quality, performance, and function in stunning harmony. The CDP-300 will be available June 2005, at a manufacturer’s suggested price of $6,500 (US).
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Hi-Fi Components
Harman set to acquire iconic premium audio brands including Marantz, Bowers & Wilkins, Denon, Polk Audio, and more.
HEOS Built-in becomes Powered by HEOS. New branding with improved features deliver multi-room audio and lossless music streaming that actually works, no gimmicks required.
Ask an Expert
Just like Sonos, HEOS enables multiroom music streaming, but with higher quality audio and more device choices. Here's what it is and how to...
At $12,000, the Delta PRE Mk II is the first Classé preamplifier to get HEOS built-in for music streaming and whole-home integration.
Podcasts
A/V Industry veteran, Philip Jones of Sound United and co-owner of ProjectorReviews.com shares his passion for hi-fi and home theater, along with some interesting...
A “Force” to be Reckoned With: 5 Power Amps, Stereo Preamp, Integrated Amp, and CD Player are Just the Beginning Montreal, Canada–Aug. 2004–In the...
Montreal, Quebec, Canada–Aug. 2004–Five new power amplifiers from internationally respected high-end audio maker Classe Audio anchor the new Delta family, which marks the most...
Montreal, Canada–Aug. 2004–Among the eight components that introduce Classe Audio’s stunning new Delta lineup are a stereo preamplifier and integrated amp. Both feature the...
