Car Amplifiers
Clarion XC6410 and XC6210 Car/Marine Amplifiers
For 2012, Clarion announced the XC high performance full range Class D digital amplifiers with compact size for automotive or marine use. The all-new XC series amplifiers feature electronic high and low-pass crossovers, PWM regulated MOS-FET power supply, variable bass boost control and auto sense remote turn-on via RCA input. The XC6410 4-channel amplifier offers 600 watts of maximum power output and the XC6210 2-channel amplifier boasts 350 watts of maximum power output. Both XC amplifiers offer 125 watts per channel at 4 ohms or 250 watts at 2 ohms when bridged.
Their sleek new cosmetics and small package offer ultimate flexibility and are also rated and durable enough for marine use with corrosion resistant RCA and block terminals.
Clarion XC6210 Car Amplifier
XC Class D High Performance Compact Size Amplifiers Feature:
  • Class D Topology Power Supply
  • PWM Regulated MOS-FET Power Supply
  • Variable High and Low-Pass Crossover
  • Auto Sense Remote Turn-On via RCA Input
  • Variable Bass Boost Control
  • Soft Turn-On and Turn-Off Circuitry
  • Ground Loop Isolation Circuit
  • Corrosion Resistant ABYC Compliant Connectors
  • Meets or Exceeds ASTM D4329 (UV Exposure)
Specifications
XC6410 XC6210
Type 4/3/2 Channel Power Amplifier 2/1 Channel Power Amplifier
MSRP $499.99 $379.99
Output 125 Watts x 4 Continuous @ 2-Ohms 125 Watts x 2 Continuous @ 2-Ohms
85 Watts x 4 Continuous @ 4-Ohms 85 Watts x 2 Continuous @ 4-Ohms
250 Watts x 2 Continuous @ 4-Ohms Bridged 250 Watts x 1 Continuous @ 4-Ohms Bridged
Dimensions 8 3/4″ x 6 7/8″ x 2 3/16″ 6 3/8″ x 6 7/8″ x 2 3/16″
1 Comment
1 Comment
  1. Martin
    July 3, 2012 at 5:29 am
    How can I get affordable Price Car Amplifier?
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
