Cisco Linksys E4200 Dual-Band Wireless-N Router
Cisco today unveiled its best-in-class wireless home router — the Linksys E4200 Maximum Performance Dual-Band Wireless-N Router. Designed for optimum home theater performance, the E4200 works seamlessly with the latest entertainment devices, including Internet TVs, iPad tablets, game consoles, smart phones, e-readers, and VoIP devices. This new router not only helps boost performance and range in the home, it provides industry-leading speed of up to 450 Mbps for smooth streaming of video and music and uninterrupted gaming.
Building on the decade of leadership and innovation from Linksys, this latest state of the art router features simultaneous dual-band wireless-N, four gigabit ports, and a 3×3 antenna configuration that help give it unparalleled speed and range. Additionally, a combination of internal and external amplifiers coupled with six antennas help increase the signal strength across greater distances, providing improved home network coverage and reducing dead spots. The E4200 also features a next-generation industrial design that combines sleek contours with advanced functionality.
New Features for Storage, Sharing, and Simple Setup
The E4200's new USB feature makes it easy to add external storage to the network and since it is an UPnP Media server as well, consumers can easily store, share and stream movies, music and games to other devices around the home. The USB port also has plans for converting to a Virtual USB port which will also enable printers to easily connect to the network so all users in the home can print wirelessly. The included Cisco Connect software continues to provide simple three-step setup and network management tools such as parental controls and guest access.
Linksys E4200 Maximum Performance Dual-Band Wireless-N Router - Back
Performance:
  • Maximum performance of up to 300 Mbps (2.4) and up to 450 Mbps (5.0GHz)
  • Simultaneous dual-band (2.4 and 5.0 GHz) with four 10/100/100 gigabit ports
  • 3×3 internal MIMO special stream configuration on the 5.0 Ghz band for ideal performance for streaming HD videos, gaming and voice
  • Internal and external amplifiers for maximum speed at greater distances for added in-home mobility
  • Six antennas for maximum range
Features:
  • Quality of Service (QoS) for prioritizing bandwidth for movies, voice or music
  • UPnP media server for adding on storage to serve your Internet-enabled TVs or media server PCs
  • USB port for easily adding external storage drives
  • New design
Software:
  • Advanced security: WPA and WPA2 and Stateful Packet Inspection (SPI) Firewall
  • Plans to support IPv6 in the spring
  • Cisco Connect software for enabling simple setup, network management tools (parental controls, guest access) and optional advanced settings
Pricing and Availability
The Linksys E4200 Maximum Performance Dual-Band Wireless-N Router is immediately available for $179.99.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
