Cisco introduced its new Linksys E-Series suite of powerful and easy-to-use next-generation Wireless-N routers and switches, available today. The new Linksys E-Series lineup includes five routers, each with the latest technology in home wireless for a multitude of home entertainment experiences. The new routers not only provide the performance needed for today's connected home, but also help to future-proof for new and emerging media technologies that are gaining traction with consumers such as Netflix-ready TVs, Blu-ray players, and game consoles, as well as Cisco's umi telepresence. Designed with faster speeds (up to 450 Mbps), other key features for select routers in the line include a 3×3 spatial stream configuration for improved coverage, external power amplifiers to maintain signal strength over a greater distance and reduce dead spots, and virtual USB technology to connect USB printers, storage, and other devices to the network.
Cisco Connect Software Enables Easy Setup and Network Management
Each of the Linksys E-Series routers includes the acclaimed Cisco Connect software that enables consumers to set up and manage their wireless home network effortlessly. Unlike other wireless products that require 20 to 30 complicated steps to set up a single computer, Cisco Connect takes the user through three simple steps from start to finish. The included Cisco Connect software makes it easy to: 1) add additional devices to the network, 2) set parental controls, 3) provide Internet access for guests on a separate guest network and 4) customize personal security settings such as passwords. Advanced users can also configure and manage their routers via a web browser.
The new routers feature the latest version of Cisco Connect, which now includes an Internet Speed Test that can check the bandwidth and speed of a user's Internet connection.
E-Series Wireless-N Routers
Model | Linksys E1200 Wireless-N Router | Linksys E1500 Wireless-N Router with SpeedBoost | Linksys E2500 Advanced Dual-Band Wireless-N Router | Linksys E3200 High Performance Dual-Band N Router | Linksys E4200 Maximum Performance Dual-Band N Router |
SRP | $59.99 | $79.99 | $99.99 | $159.99 | $179.99 |
Bands | 2.4 GHz | 2.4 GHz | 2.4 GHz Dual-Band 2.4 GHz + 5 GHz |
Speed | Up to 300 Mbps | Up to 300 Mbps | Up to 300 + 300 Mbps | Up to 300 + 300 Mbps | Up to 300 + 450 Mbps |
Transmit/Receive | 2 x 2 | 2 x 3 | 2 x 2 | 2×3 | 2.4 GHz: 2×3 5 GHz: 3×3 |
Amplifiers | Integrated On-chip |
External Off-chip |
External Off-chip High Power |
Ports | 4 x 10/100 | 4 x 10/100 | 4 x 10/100 | 4 x Gigabit USB |
4 x Gigabit USB |
USB Features | N/A | N/A | N/A | Shared Storage Virtual USB |
Shared Storage Virtual USB Media Server |
E-Series Switches
The three new Linksys switches enable faster and simpler wired connections. New features include plug and play of Ethernet-enabled devices, Quality of Service (QoS) for traffic prioritization, auto-sensing ports, and power saving features.
Model | Linksys SE1500 5-Port 10/100 Switch | Linksys SE2500 5-Port Gigabit Switch | Linksys SE2800 8-Port Gigabit Switch |
SRP | $29.99 | $54.99 | $74.99 |
Ethernet Ports/Speed | 5 x 10/100 | 5 x Gigabit | 8 x Gigabit |
Per Port Status LEDs | Yes | Yes | Yes |
Power Saving Features | Cable connect detection | Cable connect detection Sleep mode |
