Cineversum BlackWing One Projector
New Entry-level Full HD Projector is Long on Performance and Features, Blended with European Styling and Craftsmanship
Cineversum, a cutting-edge brand of video products for the residential market, has announced their BlackWing One digital video projector in the North American market. StJohn Group, exclusive North American distributor and marketer for the product line, will ship the first units in mid-December.
The BlackWing One (MSRP $6,500) is a state-of-the-art multi-use full-HD 1080P 24P, digital projector and integrates the latest technologies available on the market such as three 0.6″ LCoS panels at a native resolution of 1920×1080 pixels, pre-calibration to D65 and CIE rec 709 high definition color space, >15,000:1 dynamic contrast ratio, and two HDMI 1.3 connections.
The BlackWing One joins the existing line-up of BlackWing Two ($9,995 MSRP) and BlackWing Three ($13,500) 3-chip LCoS models.
The ultra quiet, projector is housed inside a futuristic deep metallic-black ABS plastic chassis designed by the famed French designer Antoine Beon. The design celebrates the concept of speed and precision with an unforgettable futuristic shape reminiscent of the Stealth Fighter; hence, the name BlackWing.
Custom colors are available making the designer-friendly model easy to integrate into a wide variety of decors. Custom in-field calibration and automation is made available for qualified installing specialists via the BlackWing One’s RS232 communication port.
John Caldwell, sales director for StJohn Group, stated, “What sets Cineversum apart is their unique combination of proven 3-chip performance that incorporates cutting edge deep color technology, with hand calibration for today’s HD sources like broadcast and Blu-ray. Combine this with features like vertical image stretch for 2.35 cinemascope viewing, the finest quality materials, lowest operating noise level, Euro styling and unmatched attention to detail, and the results are astonishing. The BlackWing One is quite possibly the finest value in a home theater projector available under $7,000.”
Key BlackWing One Features:
  • 1080p24 format compatible: “cinema-like” motion.
  • Optimized out-of-the-box settings and pre-calibrated for D65 and CIE rec: 709 High Definition Color Space
  • Full-glass Ultimate Reference Lens™ for variable electronic aperture control for optimizing brightness and contrast according to room light levels.
  • Greater than 15,000:1 dynamic contrast ratio
  • 1400 ANSI lumens Brightness
  • +/- 60% vertical, +/- 30% horizontal Lens shift
  • Zoom 1.5x (1.5-2.2:1 throw ratio)
  • 2x HDMI 1.3 inputs, plus one each: VGA, Component, Composite and S-video input
  • Internal HQV video processor/scaler that adapts for wide range of film and video cadences plus enhances the input signal and removes video noise.
  • Ultra-Silent fan (< 20 dB)
  • Color Management System (C,Y,M,R,G,B gain and saturation).
  • Discrete IRE range RGB gamma
  • Home Automation friendly (RS232 via D-sub 9)
  • Keystone correction
  • Two 12V triggers for controlling screens, curtains etc.
  • Custom colors available
  • Can be upgraded with 2.35:1 Cinemax or 2.35 THEATRE Concept for constant height, 2.35 viewing.
  • Elegant French design
Engineered by Cineversum in Paris, France, every single projector is also carefully tested and hand-calibrated individually by the company’s highly experienced video engineers to their European CRT like tuning standards. The color temperature (reference to D65) and the white field uniformity are optimized to provide very natural picture quality.
Installation Versatility
In addition to being a top notch performer, BlackWing One is extremely easy to install. The 1.5x (1.5-2.2:1 throw ratio) makes it compatible with virtually any kind of room. The vertical and horizontal lens shift capability can address any challenging configuration. With the keystone correction, it is child’s play to adjust the projector for the most razor-sharp picture.
For projection on 2.37 screens such as the new TAM Masking Screens from Screen Excellence, and others, the BlackWing One can also be easily retrofitted with its Theater Concept Kit consisting of a quick motorized sled for moving an anamorophic lens into place for constant height projection of cinemascope material. Thanks to the optional Cinemax Kit (a permanent anamorphic converter fixed in front of the projector), BlackWing One can display a wide picture, respecting the original 2.37:1 aspect ratio of the movies. With only one key of the remote control, the user will be able to switch from the classic 16:9 aspect ratio to a breathtaking Cinemascope format. The exclusive Cineversum Theatre Mode made this possible.
The real purists, seeking a premium cinema-like projection, will opt for the Theater Concept Kit consisting of a whisper quiet and quick motorized sled for moving a first-grade anamorphic lens into place for constant height projection of cinemascope material.
The BlackWing One is available to order now.
The BlackWing line, dedicated to the professional A/V installer, was awarded the prestigious Product of the Year 2008 award by Electronic House magazine.
About Cineversum
Cineversum initially was conceived as the dedicated consumer brand for famed Belgian video manufacturer Barco. In September 2004, Technic Electronic Conseil (T.E.C.) took over worldwide distribution of Barco’s home theater business, including the Cineversum name. T.E.C. is based in the Montmartre district of Paris, France.
Led by French industry veteran and pioneer Jean-Claude Younes, T.E.C. has successfully developed the Cineversum Home Cinema Concept. In close cooperation with partners such as Barco, Cineversum has steadily built a range of cutting-edge video products for the professional home theater market and are distributing them worldwide through a network of specialist distributors.
The Cineversum line is the perfect complement to the premium brands already in the StJohn Group portfolio of design-first brands.
About StJohn Group
StJohn Group, Inc. is not a typical American distributor. Only representing lines offering exclusive North American distribution opportunity allows the company to closely work with its partners on a holistic approach to brand development. Unlike most U.S. distributors, StJohn Group handles all facets of sales and marketing, including literature and collateral creative and production, advertising creative and buys, media relations, web sites, business development and long range market planning.
Based in Bellingham, WA with a satellite office in Ventura, CA, StJohn Group has seventeen regional representative firms and an active roster of more than 850 specialty A/V dealers.
StJohn Group specializes in products and services for the custom integration (CI) market – both residential and commercial – and represents Artcoustic and Cabasse Loudspeakers, Cineversum, iSky Panels and Screen Excellence in North America and the Caribbean.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
