Audio Cables
The Chord Company’s ShawlineX ARAY Cables Get an Upgrade
The ShawlineX Aray interconnect cables from Chord Company offer a significant upgrade over the previous iteration. Our review is forthcoming next week.
Chord Company Shawline X Aray Cables
Following the recent release of its EpicX Array interconnect cable line the Chord Company has upgraded its more affordably priced Shawline analog interconnect with XLPE (Cross-linked Polythene) insulation, making it the best-performing Shawline cable yet.
The new ShawlineX ARAY is the latest in a line of handmade-in-the-UK cables from Chord Company to benefit from XLPE following in the steps of the SignatureX and EpicX ARAY interconnects earlier in 2023.
Silver-Plated Conductors: In addition to the XLPE upgrade, the ShawlineX Aray cables also incorporate high-quality silver-plated conductors, several layers of shielding, and proprietary Chord Company ARAY geometry.
ChorAlloy: The ShawlineX ARAY cables also incorporate ChorAlloy™-plated, DIN, VEE 3 RCA, or XLR connectors, plus additional material technologies.
Other Shawline Cables: The rest of the Shawline range is comprehensive, boasting a dedicated tonearm cable, mini-jack options, HDMI AOC (Active Optical Cables), power and speaker cables, plus a variety of digital connections.
Tip: The ShawlineX ARAY comes with a lifetime warranty against defective materials and workmanship.
Price and availability
The ShawlineX ARAY cable Line is priced from £210 (0.5 m length) and is available now with custom lengths and terminations to order through Authorized Chord Company Dealers.
Tip: Our review of the ShawlineX Aray cables is forthcoming next week.
Note: Chord Company (cable maker) and Chord Electronics (high-end audio component maker) are separate companies.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Audio Cables
High-end cables made in France? Do British and American manufacturers need to be concerned? The Advance Paris LINK have us excited to try them.
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Audio Cables
At £10 per/meter, the Chord Company Leyline2XL are 14 AWG speaker cables designed for custom installers that require long cable runs.
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Audio Cables
Improve digital connections between devices with Chord Company's Epic Digital Tuned ARAY Interconnects with RCA, BNC, or AES-EBU terminations.
Audio Cables
Connect to some of the great DACs of the past with ddHiFi's remarkable TC100 and TC100S USB-C to Digital Coaxial Converters.
QED and Chord Company proved to us you don't need to spend exorbitant amounts of money on speaker cables to get great sound.
