Chord Company’s PowerHAUS P6 Powerblock Unveiled
Reduce noise and improve the performance your hi-fi system with Chord Company’s most affordable mains distribution block.
Chord Company PowerHaus P6 Mains Distribution Block
Audiophiles have used power line conditioners for decades as a method of protecting equipment from power surges and cleaning up the quality of power that their equipment receives. One can spend anywhere from $50 to $5,000 on a single unit and the merits are certainly system specific.
With that in mind, Chord Company offers several power distribution products that are designed for different applications.
The new PowerHAUS P6, drawing on Chord Company’s near 40-year expertise in wiring design, engineering, and manufacturing techniques, is designed to reduce noise and improve the performance of hi-fi, home cinema, and CI (Custom Install) systems.
Chord Company PowerHaus P6 Mains Distribution Block with Cable
PowerHAUS P6
The PowerHAUS P6 builds on its direct predecessors, the M6 and S6 which were launched in 2022. The P6 maintains Chord Company’s philosophy of design expertise, versatility, high-level build, and proprietary ARAY noise-reduction technology.
Internally, the PowerHAUS P6 uses heavy-gauge cables and high-quality sockets which are combined with a 16 amp input socket that meets IEC (International Electrotechnical Commission) standards, which is suitable for demanding systems.
Chord Company’s PowerHAUS technology doesn’t use serial filters, switches, and neon power indicators which can generate noise and compromise performance. Solid construction also provides the optimum environment for the sophisticated internal circuitry.
In addition, Chord Company has minimized the interaction between internal live, neutral, and earth cables and tried to maintain, wherever possible, a clean earth supply, based on experience gained developing the company’s proprietary noise-reducing ARAY technology.
Chord Company PowerHaus P6 Mains Distribution Block with Cables Connected
The PowerHaus P6 comes with a standard, straight connector 16 amp IEC power cable, but can be upgraded with factory options, such as the Clearway Power cable with right-angle connectors.
Specifications
  • Output Sockets: 6 (UK or Euro)
  • Input Socket: 16 amp IEC
  • Outlet ratings: 13 amp (UK)/16 amp (EU)
  • Rated power and/or current: max 16 A
  • Supply Voltage: 100-250 V
  • Frequency: 50/60 Hz
  • Dimensions: 520 mm x 112 mm x 65 mm (L x H x D)
Chord Company PowerHaus P6 Mains Distribution Block Package
Price & Availability
The PowerHAUS P6 is handmade in England and priced at £600 (British Pounds). It is available through authorized dealers.  A U.S. version is expected, but a release date has not been provided.
Note: Chord Company (cable maker) and Chord Electronics (high-end audio component maker) are separate companies.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Audio Cables
High-end cables made in France? Do British and American manufacturers need to be concerned? The Advance Paris LINK have us excited to try them.
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Audio Cables
At £10 per/meter, the Chord Company Leyline2XL are 14 AWG speaker cables designed for custom installers that require long cable runs.
At $3,000, the McIntosh MIP200 Power Controller offers power protection and peach of mind for up to 8 audio components.
Audio Cables
Improve digital connections between devices with Chord Company's Epic Digital Tuned ARAY Interconnects with RCA, BNC, or AES-EBU terminations.
For $299, the SilentPower LAN iPurifier Pro promises to prevent interferences coming through an ethernet cable from reaching audio devices.
A/V Furniture & Accessories
For $375, Toneoptic offers an innovative wall-mounted vinyl record storage solution you'll actually flip out for.
