Chord Introduces BerTTi Stereo Power Amplifier
Chord brings ULTIMA topology into its affordable Table Top (TT) stereo power amplifier for £3,995.
Chord Bertti Stereo Power Amplifier with Hugo TT 2 and M Scaler in Black
Chord Electronics has launched its most affordable ULTIMA-technology stereo power amplifier to date called BerTTi (£3,995). The new power amp also introduces the company’s next-generation ULTIMA topology to the ground-breaking Table Top (TT) range, home to the Hugo TT 2 DAC/pre/head amp and Hugo M Scaler upscaler (pictured above).
BerTTi is a fully balanced 75-watt stereo power amplifier benefitting from the latest dual-feed-forward error-correction topology. BerTTi directly replaces its predecessor, the TToby, and expands the ULTIMA-topology range of amplifiers designed by Chord Electronics owner and founder John Franks. Franks’ advanced ULTIMA error-correction technology monitors and immediately corrects signals before the output stage for astonishing accuracy.
Chord Bertti Stereo Power Amplifier Front and Back
BerTTi features both balanced and unbalanced inputs, high-quality gold-plated loudspeaker outputs, plus a 10 A IEC power inlet. Further features include two modified power supplies for increased performance, plus an additional auxiliary power rail for the front end, which provides extra voltage to drive the custom-made MOSFETs.
The new ULTIMA-tech BerTTi, when combined with the resolving power of the award-winning Hugo TT 2 DAC/preamp ($6,725), claims new levels of sonic performance from a small system. The addition of the Hugo M Scaler ($5,650) upscaler, with the ability to upscale audio to 705.6 kHz, 16x CD’s native resolution, makes the three-box system quite compelling.
Speaking about the new BerTTi stereo power amplifier, John Franks said: “BerTTi utilizes our proprietary ULTIMA technology which continuously monitors the electrical and thermal performance parameters for each of the MOSFET power devices used within this advanced design. This additional circuitry adds an extra layer of control in the power components’ topology that lowers all distortion modes when compared to ordinary high-quality amplifier designs. BerTTi can drive loudspeakers, from bookshelf types to the hardest-to-drive floorstanders without difficulty.”
Chord Bertti Stereo Power Amplifier Top
BerTTi’s sleek metalwork is precision-machined from solid aircraft-grade aluminium and is available in a choice of Jett Black or Argent Silver.
BerTTi follows a line of highly advanced full-width ULTIMA-technology power amplifiers, including the original flagship ULTIMA mono power amplifier (780 W), the successive ULTIMA 2 (750 W) and 3 (480 W) mono power amplifiers, the ULTIMA 5 (350 W) and 6 (180 W) stereo power amplifiers and in May 2023, the new ULTIMA INTEGRATED
Specifications
  • Output power: 75 W into 8 Ω
  • Frequency response: 5 Hz-100 kHz +/- 0.5 dB
  • Input impedance: 100 kΩ
  • THD: 0.008 %
  • Gain: 30 dB
  • SNR: 87 dB (A-weighted)
Price and availability
The Chord BerTTi is available to pre-order now (expected September) £3,995.
For more information: chordelectronics.co.uk
Related reading:
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
Lots of power, practical integration and control, and a reasonable price tag make the Wotan power amp worth consideration, especially if you own other...
For $25K, TAD's Evolution Series 250-watt per channel stereo power amplifier promises even greater purity, responsiveness, and accuracy.
Using GaN technology, Starkrimson Mono Ultra Premium power amplifier boasts 250-watts of power at 8 ohms, 500-watts at 4 ohms.
The Marantz AV 10 Preamp/Processor and AMP 10 Power Amplifier are capable of delivering 15.4 channels of surround sound.
With 300-watts per channel RMS, Goldmund claims Telos 800 is one of the finest Stereo Power Amplifiers ever crafted.
With fully balanced and improved circuitry throughout, the BAT VK-85 Preamp and REX 300 Amp claim pure musicality from a $27,500 combo.
Leema Acoustics makes its case for stereo separates. The new Quantum series combo is £2,800 and made in the U.K.
