Chord Anni Desktop Integrated Amplifier Offers ULTIMA Technology
The Chord Anni Desktop Integrated Amplifier completes the circle and delivers their award-winning ULTIMA technology for high-sensitivity speakers.
If you’re interested in desktop audio, this new product introduction from Chord is definitely worth a listen. The Chord Anni Desktop Integrated Amplifier completes the circle for the British manufacturer adding an amplifier capable of driving far more loudspeakers than its modest power rating would suggest.
Capable of driving both headphones and compact loudspeakers, the Qutest-sized Anni benefits from the company’s proprietary ULTIMA circuit topology and is perfectly positioned to exploit the full potential of today’s high-performance headphones, desktop monitors and high-resolution audio sources.
Chord Huei, Qutest and Anni Stack with Kef Bookshelf Speaker
Top to bottom: Chord Huei, Chord Qutest and Chord Anni
The new Anni desktop integrated amplifier forms part of the Qutest range and seamlessly complements the resolving abilities of the multi-award-winning Qutest standalone DAC and Huei Phono Stage which we reviewed in August.
As a system, the Qutest components provide an unrivalled desktop audio solution, offering class-leading digital and analogue technologies for the modern music lover. The company’s compact QSS (Qutest Stand System) modular equipment rack provides the perfect support, too.
Chord Huei, Chord Qutest and Chord Anni Front
Anni offers Chord Electronics’ recently announced dual-feed-forward error-correction circuit topology whether using headphones or compact loudspeakers. Anni’s advanced technology allows it to drive any headphone load, error-monitored and compensated amplification at all times.
Chord Huei, Qutest and Anni Stack Rear
Benefitting from both 3.5 mm headphone outputs and ¼-inch (6.35 mm) outputs, so two can listen simultaneously, plus 4 mm banana-type loudspeaker outputs, Anni delivers 10 watts of Chord Electronics-quality ULTIMA amplification, controlled by a fascia-mounted volume control that also doubles as an input selector switch for Anni’s two line-level inputs.
10 watts might not seem like a lot of power, but in a desktop scenario with high sensitivity loudspeakers — you are unlikely to require a lot of power.
A two-stage gain control for loudspeakers provides additional flexibility with a wide range of desktop monitors.
Chord Anni Headphone Amplifier Front
Chord Anni
Anni benefits from the same UK-made precision CNC-machined high-grade aluminium casework common to all Chord Electronics’ products, and is entirely designed, engineered and built in the UK. The company’s trademark polychromatic control spheres govern the power and gain controls, complementing the fascia-mounted volume control/input selector.
Chord Anni Headphone Amplifier Rear
Chord Anni
Anni is powered by a 15 volt external power supply and benefits from a 12 V DC output, capable of powering the Qutest DAC and Huei phono stage when used with the new Qutest range power adaptor (supplied).
Price and Availability
Chord Anni Headphone Amplifier with Qutest DAC, MacBook and Sennheiser Headphones
Chord Qutest DAC & Anni Headphone Amp Combo
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
Does full EQ functionality and even more power make the Element IV an easy recommendation at $549?
DAPs
At $2,299, Astell&Kern found a few ways to maintain flagship audiophile DAP performance at a lower cost. Find out what's changed.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
At $1,300, is the STAX SRM-400S capable of driving some of the best headphones in the world?
At $1,999, Orchard Audio Valencia is a balanced desktop power amplifier designed for headphones, but powerful enough for speakers.
FiiO expands its line-up with K17 Headphone Amp, which provides a lot of features and connectivity that raise the price, but should please any...
At $4,320, the Chord Alto is a compact desktop amplifier that powers up to four headphones, a pair of speakers, and also functions as...
