Carver Digital SW-500DC and SW-350DC Subwoofers
New High-Pressure, High-Output Subs Ideal for Use in Audio Systems and Home Theaters
Carver Digital introduces the compact and powered SW-500DC and SW-350DC High-Pressure Subwoofers at the International Consumer Electronics Show, in Las Vegas.
Carver Digital’s new subwoofers are both high-pressure, high-output, front-firing powerhouses featuring a 12-inch woofer in the SW-500DC, a 10-inch woofer in the SW-350DC, and built-in tracking downconverter amplifiers in both. They’re ideal for use in audio systems and home theaters, individually or in groups.
The high-pressure design allows the subs to deliver an unusually high level of low bass energy in a compact housing. The tracking downconverter amplifier lets the subs anticipate dramatic sound level changes and automatically adjust the amplification needed to improve the signal’s dynamics. The fast response also helps any receiver that’s connected to run more efficiently and generate less heat.
The SW-500DC delivers 500 watts RMS and features a frequency response of 18Hz — 260Hz, a 163mV input sensitivity for the rated power, and an input impedance of 10.8 kOhm. The amp’s efficiency is greater than 83 percent. The SW-350DC delivers 350 watts RMS and features a frequency response of 20Hz — 180Hz, a 100mV input sensitivity, and an input impedance of 15 kOhm. The amp’s efficiency is greater than 80 percent.
Both subwoofers feature an ergonomic design with a durable polyester resin finish, gold-plated RCA inputs and outputs, and fully controllable gain, crossover frequency, and phase controls. They also share an auto-on/off power setting, banana post speaker level inputs and pass-through outputs for two channels, aluminum cone isolation feet, and a removable IEC power cord.
Carver Digital’s SW-500DC and SW-350DC subwoofers will be available in Spring 2005. They were seen with other fine products from Phoenix Gold in Booth 20968, Las Vegas Convention Center, during CES.
Phoenix Gold International, Inc. (www.pinksheets.com: PGLD), founded in 1985 and located in Portland, Oregon, designs, manufactures, and sells innovative high quality, high performance electronics, accessories and speakers to the audio market. The Company’s products are used in the car audio aftermarket, professional sound installations, and in custom audio/video and home theater applications. Products are sold under the brand names Phoenix Gold, Carver, Carver Digital, Carver Professional, and AudioSource.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
