Canton’s Limited Edition Reference GS Join The Parade of Statement Loudspeakers in 2024
At $60,000/pair, the new flagship Canton Reference GS Loudspeaker will be limited to 50 pairs worldwide.
Canton Reference GS Limited Edition Loudspeakers Lifestyle
The growing parade of flagship loudspeakers priced above $60,000 has become a topic of conversation behind the scenes recently and more than a few of us are slightly puzzled why manufacturers are taking this approach.
Innovation is key to growth and there is no issue with companies attempting to push boundaries and create the best possible loudspeakers that they can — we just question why there isn’t more of a push at the bottom with entry-level and mid-tier loudspeakers that are active or wireless.
If you can create state-of-the-art loudspeakers between $60,000 and $750,000 — which only appeal to a select few on the planet, then clearly you have the capabilities to deliver on the promise of better sound quality for the rest of us.
The 99% of the population who might actually want to buy it.
Canton’s new Reference GS Limited Edition loudspeakers will be limited to only 50 pairs and on the surface — look extremely impressive. The company claims that these new flagship models are the best they have ever created; they certainly have some competition from DALI, Magico, and Focal at the price point.
These floorstanding loudspeakers are 64 inches tall, 18 inches wide, 28 inches deep, and weigh 340 pounds apiece.
The Reference GS loudspeakers are handcrafted with elements of wood, metal, and lacquer to create a distinct artistic look.
Tip: Check out our previous coverage of the Canton Reference Loudspeakers, which are the foundation of the Reference GS Limited Edition model.
Multi-Layer Specially Reinforced Cabinets
The redesigned Reference GS cabinet uses round baffles for the first time. The 3-inch thick baffles are manufactured on a 5-axis CNC milling machine.
Canton Reference GS Limited Edition Loudspeaker Top Front
The curved side panels, bases, and lids are made of multi-layer, 1-inch thick wood laminate. This provides added stability with a significant reduction in natural resonance.
To control the forces inside the Reference GS loudspeakers, computer-optimized reinforcement was used in its design. Internal standing waves are prevented by the selection of the front shape, baffle, and a precisely defined damping material made of a special fleece.
In addition, real wood side panels are firmly attached to the side panels. This stiffens the enclosure, further reducing unwanted resonance. The curves enable an acoustically optimized enclosure design, preventing edge reflections.
Diamond Tweeter
In a Canton first, a diamond dome tweeter is being used. in the Reference GS Limited Edition speakers. This cone material enhances high-frequency reproduction with more precise detail even at the highest volume levels.
Canton Reference GS Limited Edition Loudspeaker Top Midrange
Midrange and Woofers
Just as with the Canton Reference Series, the GS Limited Edition incorporates  BCT (Black Ceramic Tungsten) and TCC (Triple Curved Cone) technology in the midrange drivers.
The woofers incorporate a Black Keramik-Wolfram wave surround, double cone construction.
Unique Crossovers
In combination with Displacement Control, the crossover of these speakers prevents uncontrolled excursion of the woofers and increases the bandwidth with the same cabinet size. The result is precise bass even at the highest sound pressure levels. These new crossovers contribute to stress-free music enjoyment at all frequencies and volume levels.
Canton Reference GS Limited Edition Loudspeaker Rear Panel Adjustments
Canton Room Compensation technology
In addition to the tweeter and mid-range level adjustment found on the Reference Series, Reference GS adds adjustment for the bass sensitivity in 5.1 dB steps. This allows the speakers to be optimized to suit both personal listening tastes and room acoustics.
Wave Sicke 3.0
Three congruent surround bends are included in the drivers to ensure balanced force symmetry. This feature guarantees even transient and decay higher levels when necessary.
Absorbent Sealing Rings
Special sealing rings were developed for the Reference GS Limited Edition. The rings are flocked with a special fabric that achieves two important goals:
  1. Ensures complete sealing of the air volume in the speaker enclosure.
  2. Effectively reduces the transmission of the structure-borne vibrations.
Canton Reference GS Limited Edition Loudspeaker Base Plate Rear
Insulation Bass Plate
The Reference GS Limited Edition has been equipped with a redesigned base plate that enables the installation of solid, height-adjustable, stainless steel feet. Combined with supplied absorbers, these serve to almost completely decouple the speaker from the floor.
Comparison
Canton Reference GS vs. Reference 1 Loudspeakers
Reference GS Limited EditonReference 1
Speaker DesignFloorstandingFloorstanding
Speaker Type3-way/Bass Reflex3-Way/Bass Reflex
Power Handling 500 to 950 watts450 to 820 watts
Woofer4 x 8.6″ (219mm)3 x 8.6″ (219mm)
Midrange1 x 6.85″ (174mm)1 x 6.85″ (174mm)
Tweeter1 x 1″ (25mm)1 x 1″ (25mm)
Efficiency (2.83 v/1m)89 dB88 dB
Frequency Response18 to 40,000 Hz18 to 40,000 Hz
Crossover Points160 and 3,100 Hz170 and 3,000 Hz
Impedance4 to 8 ohms4 to 8 ohms
Dimensions
(WxHxD with Base)
18.1 x 64 x 28 inches
(46 x 163 x 72 cm)
15.4 x 52.4 x 2.48 inches
(39 x 133 x 6.3 cm)
Weight342 lbs
(155 kg)
179 lbs
(81 kg)
Price (Pair)$60,000 (US)
$79,000 (CAN)
$25,000 (US)
$33,000 (CAN)
Canton Reference GS Limited Edition Loudspeakers Front and Side
Pricing, Finishes, and Availability
The Reference GS is limited to 50 pairs worldwide. It is offered in one finish as shown above. Retail price is $60,000/pair in the USA and $79,000/pair in Canada. Shipping now via Bluebird Audio and Authorized Dealers.
Tip: The speakers include a 10-year warranty.
canton-reference-gs-loudspeaker-rear-top
1 Comment
1 Comment
  1. Keith McAvoy
    April 3, 2024 at 4:51 am
    Yes,I too found it puzzling why in God’s name so many speaker manufacturers, building and pricing speakers in the stratosphere. What audio going after the deep, deep pocket customer only?
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
