Canton Unveils 2023 Reference Series Speaker Lineup
Canton’s new Reference Series Loudspeakers are finally available in North America from Bluebird Music. We have a detailed breakdown of each model.
Canton Reference 2023 Loudspeakers, Center Speaker and Subwoofer
Canton has announced its Reference 2023 loudspeaker series. Designed for both hi-fi and home theater systems, there are 8 new models divided into 4 categories.
  • Floorstanding: Reference 1, 2, 3, 5, 7
  • Bookshelf/Compact: Reference 9
  • Center Channel: Reference Center
  • Subwoofer: Reference Sub
Update 11/22/2023: Available in the US and Canada!
Core Features
Before we get into details on each speaker, here are some core features they all share.
Canton Reference 1
Canton Reference 1
Innovative Cabinet Design
The Canton Reference Series features a modern rounded exterior design and meticulously engineered accents and interior structure that support optimum sound reproduction while minimizing undesired resonance issues. Each model incorporates computer-simulated internal reinforcement to minimize vibrations. In addition, a new bass guide allows for deep and powerful bass reproduction.
Canton Reference 2 Loudspeaker
Canton Reference 2
Material Versus Technology
To achieve the effective balance between stiffness and weight, BCT (Black Ceramic Tungsten) membranes used in low and midrange drivers transform 25% of the molecular structure of an aluminum cone into a ceramic structure, refined further with tungsten and other metal particles.
The specially black midrange ceramic cone incorporates TCC (Triple Curved Cone) technology which further stabilizes the membrane, reducing unwanted resonances and distortions.
To deliver crystal-clear highs, the Reference high-frequency systems use extremely light and rigid BC domes. The unique shape of the new asymmetrical wave guide optimizes radiation behavior both in the crossover range and in the high-frequency range above 15,000 Hz.
A newly introduced high-molecular-weight thermoplastic material, POM, adds the proper stiffness for acoustic damping and superior dimensional stability.
Canton Reference 3 Loudspeaker
Canton Reference 3
Canton Reference 5 Loudspeaker
Canton Reference 5
Frequency Adjustment
All the Reference Floorstanding speakers include an integrated mid-range-high-frequency adjustment, while the Reference 9 compact speaker incorporates a high-frequency adjustment. This allows listeners to compensate for room acoustics and individual listening preferences.
Canton Reference 7 Loudspeaker
Canton Reference 7
CNC Machining
The CNC machined, powder-coated steel feet for the floor-standing speakers provide better stability and minimize unwanted vibrations that might also compromise sound quality.
Flocked Gasket
A newly developed flocked gasket used in the speaker chassis ensures effective decoupling supporting better detail, further enhancing the listening experience.
Digitally Amplified Subwoofer
The digital amplifier incorporated into the Reference Subwoofer provides a 750-watt output with a low-frequency response down to 18 Hz. The Reference Subwoofer features both high-level and low-level inputs.
Canton Reference 9 Stand-mount loudspeaker
Canton Reference 9
The following comparison table provides more detailed specifications for each speaker
ModelReference 1Reference 2Reference 3Reference 5Reference 7
Speaker DesignFloorstandingFloorstandingFloorstandingFloorstandingFloorstanding
Speaker Type3-Way/Bass Reflex3-Way/Bass Reflex3-Way/Bass Reflex3-Way/Bass Reflex3-Way/Bass Reflex
Power Handling450 to 820 watts370 to 630 watts 300 to 500 watts200 to 370 watts160 to 320 watts
Woofer3 x  219mm (8.6 inches)3 x  219mm (8.6 inches)2 x 192mm (7.56 inches)2 x 174mm (6.85 inches)2 x 154mm (6 inches)
Midrange1 x 174mm (6.85 inches)1 x 174mm (6.85 inches)1 x 174mm (6.85 inches)1 x 174mm (6.85 inches)1 x 154mm (6 inches)
Tweeter1 x 25mm (1 inch)1 x 25mm (1 inch)1 x 25mm (1 inch)1 x 25mm (1 inch)1 x 25mm (1 inch)
Efficiency (2.83 v/1m)88 dB88 dB88 dB88 dB87 dB
Frequency Response18 to 40,000 Hz19 to 40,000 Hz20 to 40,000 Hz21 to 40,000 Hz23 to 40,000 Hz
Crossover Points170 and 3,000 Hz160 and 3,000 Hz180 and 3,000 Hz170 and 3,000 Hz190 and 3,200 Hz
Impedance4 to 8 ohms4 to 8 ohms4 to 8 ohms4 to 8 ohms4 to 8 ohms
Dimensions (WHD with Base)39 x 133 x 6.3 cm (15.4 x 52.4 x 2.48 inches)35 x 116 x 53 cm (13.8 x 45.7 x 20.9 inches)32 x 109 x49 cm (12.6 x 42.9 x 19.3 inches)30 x 101 x 46 cm (12 x 39.8 x 18.1 inches)28 x 98 x 43 cm (11 x 38.6 x 16.9 inches)
Weight81 kg/179 lbs62 kg/137 lbs)42 kg (92.6 lbs)36 kg (79.4 lbs)33 kg (72.75 lbs)
Price (Pair)$25,000 (US), $33,000 (CAN)$20,000 (US), $26,000 (CAN)$16,000 (US), $21,000 (CAN)$11,000 (US), $14,000 (CAN) $8,000 (US),
$10,500 (CAN)
ModelReference 9Reference Center
Speaker DesignCompact Bookshelf/Standmount SpeakerCenter Channel Speaker
Speaker Type2-way Bass Reflex3-way Bass Reflex
Power Handling125 to 220 Watts130 to 230 Watts
Woofer1 x 176 mm (7 inches)
Mid-Woofer1 x 176 mm (7 inches)
Midrange1 x 176 mm (7 inches)
Tweeter1 x 25mm (1 inch)1 x 25 mm (1 inch)
Efficiency (2.83 v/1m)87 dB88 dB
Frequency Response25 to 40,000 Hz25 to 40,000 Hz
Crossover Point2,900 Hz160 and 2,900 Hz
Dimensions (WHD)26 x 45 x 39 cm (10.2 x 17.7 x 15.4 inches) 70 x 27 x 39 cm (28 x 10.6 x 15.4 inches)
Weight18 kg/39.6 lbs26 kg/67.34 lbs)
Price (R9 pair – Center each)$5,000 (US), $6,500 (CAN)$4,000 (US), $5,200 (CAN)
ModelReference Sub
Speaker DesignPowered Subwoofer
Speaker TypeBass Reflex with Passive Diaphram (Radiator)
Power Output500/750 Watts
Woofer1 x 308 mm (12-inches)
Passive Radiator1 x 308 mm (12-inches)
Frequency Response18 to 200 Hz
Crossover 55 to 200 Hz (Adjustable)
Dimensions (WHD)49 x 59 x 53 cm (19.3 x 23.2 x 20.9 inches)
Weight37 kg/81.7 lbs)
Price (ea) $5,000 (US), $6,500 (CAN)
Availability
The Canton Reference Series is offered with White Satin, Piano Black, and Walnut finishes through authorized Canton Reference distributors such as Bluebird Music in the US.
Note: There may be some price variation on some speaker models depending on Finish.
3 Comments
3 Comments
  1. reademandweep
    September 19, 2023 at 9:35 pm
    Is this paid content?
    • Brian Mitchell
      September 19, 2023 at 9:53 pm
      No.
    • Ian White
      September 19, 2023 at 9:59 pm
      Bizarre question. But you’re welcome for all of the detailed information.
      Best,
      IW
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Hi-Fi Components
High-end manufacturers in Asia and Europe were caught off-guard by the unexpectedly high tariffs levied yesterday but one distributor was already ready.
At $60,000/pair, the new flagship Canton Reference GS Loudspeaker will be limited to 50 pairs worldwide.
The Canton Townus range includes four passive loudspeakers, two active wireless speakers and one subwoofer along with center, on-wall and height speakers for home...
The highly acclaimed Canton Vento Series Loudspeakers have arrived in N. America and we plan on reviewing at least 2 models this year.
