Loudspeakers
Canton Debuts In-Ceiling Loudspeakers
MINNEAPOLIS, MN (4/7/04) — Canton has introduced two new loudspeaker models designed for in-ceiling installation. The Canton InCeiling 50 and InCeiling 70 are two-way free-air designs with pivoting 1-inch aluminum dome tweeters and 5-1/4- and 6-1/2-inch polypropylene woofers respectively. The pivoting tweeter allows the speaker’s sound field to be adjusted to suit the acoustics of the room.
Canton’s InCeiling speakers are designed for essentially invisible installation, and with paintable frames and grilles that can be modified for any decor. They are also designed to be simple to install, and they have gold-plated clamping-speaker terminals for a very solid connection that won’t work loose with age.
The InCeiling 50 has an overall diameter of 8 inches and a mounting depth of 3-1/2 inches. It has a frequency range from 50 to 30,000 Hz, and is rated for amplifiers up to 100 watts. The InCeiling 50 is currently available at a suggested retail price of $400 per pair.
The InCeiling 70 has an overall diameter of 9-5/8 inches and a mounting depth of 4-1/4 inches. It has a frequency range from 45 to 30,000 Hz, and is rated for amplifiers up to 100 watts. The InCeiling 70 is currently available at a suggested retail price of $500 per pair.
Canton is the largest manufacturer and best-selling brand of loudspeakers in Germany. It was founded in 1973 by a group of audio enthusiasts who defined their mission “to always develop the finest loudspeakers in their class.” For more information about this and other fine Canton products, visit http://www.cantonusa.com or call 612-706-9250.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
