Canton Debuts High-End Sound for a Flat-Screen Lifestyle
Canton’s CD 300 Series loudspeakers have outstanding sound quality and a slender, brushed aluminum design to compliment modern widescreen TVs and wall-mounted video displays.
Minneapolis, MN (7/12/04) — Canton has introduced the first of a new line of slender, high performance aluminum loudspeakers designed to sonically and visually compliment modern flat-screen video displays. The Canton CD 300 series combines technology derived from the company’s high-end Karat line of loudspeakers with the sleek, brushed aluminum lifestyle design of its popular CD 100 series.
The current line consists of the CD 300 floor-standing tower speaker and the CD 360F, which includes the same driver configuration adapted for vertical or horizontal wall mounting. With their slender brushed-aluminum enclosures and silvery grills, these speakers create a very dramatic presence in a room, while delivering sound quality that will please the most demanding audiophiles.
Both speakers are sophisticated two-and-a-half way systems with four 4-inch aluminum cone drivers and an advanced version of the Canton’s lauded ADT-25 one-inch aluminum-manganese tweeter. Two of the 4-inch drivers reproduce low-frequency bass signals exclusively, while the other two reproduce both bass and midrange sounds. For bass reproduction, this arrangement provides the equivalent surface area of an 8-inch woofer in a much narrower cabinet.
The remarkable Canton ADT-25 tweeter uses a one-piece aluminum-manganese dome and voice coil former that is vastly superior to more conventional designs where a separate dome and former are glued together. Not only is this entire structure much lighter and stiffer than two-part designs, but the dome provides a large surface area to radiate heat away from the voice coil. One of the key design elements of this tweeter is the use of a very narrow voice coil gap to increase the intensity of the magnetic field. Most other tweeters have relatively wide gaps to allow a margin of error for centering the coil in the gap, but even then a small displacement can harm the performance of the tweeter. Canton has overcome this by making it possible for quality control technicians to adjust the centering of the coils using test signals and to lock them in place only when the test is perfect. Additionally, the cross-section of the coil and former is much thinner than conventional designs. These factors provide for much higher output levels, high linearity, and excellent efficiency.
The four identical 4-inch bass/midrange drivers have aluminum cones with concave dust caps, and powerful motor systems. The drivers are derivatives of the same top-quality midrange drivers used in Canton’s high-end Karat and Ergo speaker lines, and the wave system (cone, dust cap, and surround) is modeled on that used in the Karat Reference line. The motor structure has been subtly redesigned to accommodate the wider frequency demands of the bass/midrange application in the CD 300 and 360F.
Upon encountering the Canton CD 300 tower speaker, the first thing that is apparent is the speaker’s unusual appearance. The 48-inch tall enclosure is less than 5 inches wide, has a depth of just over 6-inches, and is constructed of extruded aluminum with rugged pressure-cast aluminum end-caps and circular base. Bass performance is further enhanced by the use of bass-reflex topology with a single front-panel port. The careful and precise modeling of the flare on this port alone yielded a 6-dB improvement in system headroom.
The Canton CD 360F features the same basic design considerations and driver complement as the CD 300, but in a sealed cabinet that is just 23-1/2-inches long and a mere 4-inches deep. This makes it ideal for wall mounting and equally effective as a vertical speaker beside a wall-mounted video screen, or in a horizontal configuration for use as a center channel speaker. The speaker employs a sealed cabinet design to avoid having the port vent directly into the wall face. The CD 300 and CD 360F are a perfect tonal match for each other, so they can be mixed and matched within a system.
These loudspeakers are now available for suggested retail prices of $2,000 per pair for the Canton CD 300 and $800 each for the Canton CD 360F.
Canton is the largest manufacturer and best-selling brand of loudspeakers in Germany. It was founded in 1973 by a group of audio enthusiasts who defined their mission “to always develop the finest loudspeakers in their class.” For more information about this and other fine Canton products, visit http://www.cantonusa.com or call 612-706-9250.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
