Canon LV-8235 DLP Projector
Canon introduced the LV-8235 Ultra-Short Throw (UST) Multimedia DLP Projector, capable of projecting an 80-inch picture from a distance of only 1.04 ft. The LV-8235 UST can sit on a table or be mounted horizontally or vertically on a wall, ceiling or floor for a variety of 3D or 2D display applications, including educational presentations, advertising/digital signage, or museum/arcade rear-projection screens. With a high brightness rating of 2500 lumens and a maximum display size of 110 inches, the LV-8235 UST delivers its crisp imagery in the WXGA (1280 x 800) resolution 16:10 aspect ratio, which eliminates cropping or distortion when presenting HD video or graphics created on widescreen laptops. This is Canon's first DLP projector using a 0.65″ single DLP chip.
The Canon LV-8235 UST Multimedia Projector can be used for either normal 2D display or stereoscopic 3D display, depending upon user preference. The frame-sequential method of 3D display employed by the projector switches parallax images intended for the left eye and right eye at very high speed, and requires the use of active-shutter type glasses for viewers to experience stereoscopic 3D imagery.
Utilizing a newly developed ultra-short focus mirror optical system, this new model directs the images it generates through the projection lens and onto a built-in reflection mirror for loop-back through a projection window. This configuration makes it possible to use a table or a floor as a projection screen. The ultra-short throw capability also allows users to install the projector in a wide range of compact positions, including — through the use of approved brackets and attachments — horizontal or vertical wall or ceiling mounts. Examples of ultra-short throw applications include cost-effective 3D or 2D rear-projection in museums or arcades, or digital signage use in which store-front product promotions can be projected onto the sidewalk or the floor of a shopping mall to attract the attention of people walking by. The Canon LV-8235 UST Multimedia Projector is also ideal for many classroom applications where proximity to the whiteboard or screen helps to minimize the possibility of obstructions to projected images.
The LV-8235 UST Multimedia Projector's ultra-short throw capabilities and close proximity to the screen also minimize shadows as well as glare that could shine in an education or business presenter's eyes. Users in these sectors enjoy a long list of additional beneficial features that make using the projector simple to use for maximizing the effectiveness of visual communication. Other features of this new projector include:
  • Computer Synchronization – an automatic feature that turns on when a computer is connected to the projector and an input signal is detected. The feature then automatically synchronizes the projector with the computer's screen resolution.
  • Direct Power-On – useful for inaccessible ceiling-installed projectors, this feature automatically turns on the projector when the power cord is plugged into an outlet, eliminating the need to press the power switch on the unit.
  • 2000:1 Contrast Ratio – this feature ensures images with crisp blacks, depth and dimension.
  • HDMI Digital Input – provides the ability to project high-quality digital images and 1080p HD video from digital cable and satellite boxes, and a variety of HD inputs, such as Blu-ray players. Inputs for analog PC, digital PC, analog component and composite video, two analog audio inputs, and one analog audio output (for relaying audio through external speakers) are also included.
  • Built-In 10-Watt Speaker – a high-output speaker designed to provide the audio amplification needed for most classrooms and conference rooms.
  • RJ-45 Network Connection – allows users to manage and control multiple projectors from a network PC.
  • RS-232C Serial Connection – enables users to control the projector locally through a third-party control system.
  • Quiet Operation – At only 28dBA (in Eco mode), the new LV-8235 UST is exceptionally quiet. The cooling system is designed to efficiently dissipate heat while keeping the noise level at a minimum.
Price and Availability
The Canon LV-8235 UST Multimedia Projector is available now for $1,799.
See more about: New Projectors, Canon Projectors, DLP Projectors
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
