The New-Look Canon LV-7585 Projector Features 6500 ANSI Lumens and Installation Design Advantages; Compact Canon LV-7365 Multimedia Projector Provides 3000 ANSI Lumens and Superior Quality Projection Lens to Benefit Demanding Users
Canon U.S.A., Inc. has expanded its line of LCD Projectors with two new XGA-resolution models, both of which offer a wealth of advanced features designed to benefit their respective markets. The new high-performance Canon LV-7585 Multimedia Projector, designed for the installation market, is a large-venue model engineered for use in lecture halls, college auditoriums, houses of worship, museums, indoor shopping centers, corporate office lobbies and similar environments. Featuring 6500 ANSI Lumens of brightness, a contrast ratio of 1600:1, auto-winding filter system, numerous installer-friendly innovations and a standard 1.3x Genuine Canon Optical zoom lens (or a choice of four different optional high-quality interchangeable lenses), the Canon LV-7585 Multimedia Projector is an exceptionally impressive performer.
The Canon LV-7365 Multimedia Projector, meanwhile, is Canon’s brightest, compact portable model, which is designed for teachers, businesspeople and other professionals needing the advantages of powerful yet affordable presentation features while being simple, convenient to operate and lightweight.
“These two new Canon LCD projectors incorporate the latest advanced features, all of which are engineered to benefit specific categories of user needs,” said Yuichi Ishizuka, senior vice president and general manager, Consumer Imaging Group at Canon U.S.A.”Beginning with a unique design and innovative technology that goes beyond outstanding optics, these two new projectors allow Canon to meet and exceed the requirements of LCD projector installers and portable LCD projector users.”
The LV-7585 Multimedia Projector
Featuring many innovations for installers and users in ceiling-mount configurations, Canon’s new LV-7585 Multimedia Projector has a bold new design in which the lens is centered on the front panel of the projector for ease of projector placement during installation. The Canon LV-7585 Multimedia Projector also features a side-loading, easy access replacement lamp and a revolutionary auto-winding filter system, which automatically winds the filter element forward to expose a new, clean section of filter The filter can also be advanced manually using the remote control. In addition, an easy-maintenance design makes removal of the projector’s top cabinet (for panel cleaning and maintenance of optical parts) unnecessary. All of these features make installation easier and maintenance simpler, especially if the projector is in an inaccessible location.
The large-venue Canon LV-7585 Multimedia Projector provides users and installers with the flexibility of using its standard 1.3x Genuine Canon Optical zoom lens with Power Lens Shift (horizontal and vertical) or any one of four optional high-quality Genuine Canon interchangeable lenses, including an Ultra Wide Angle, Wide Angle Zoom, Long Focus Zoom or Ultra Long Focus Zoom. Images can be projected from 3l inches to 400 inches (measured diagonally). The optional LV-NI02 Network Imager enables users to send presentations to the Canon LV-7585 Multimedia Projector via the network while allowing for a variety of network control, monitoring, and image-projection functions.
The Canon LV-7585 Multimedia Projector is scheduled be available in mid-November at a manufacturer’s suggested list price of $9,999.00*.
The LV-7365 Multimedia Projector
The advantages of Genuine Canon Optics, in the form of the new Canon LV-7365 Multimedia Projector’s advanced 1.6x projection zoom lens, provide many user benefits. Chief among these is the Canon LV-7365 Multimedia Projector’s short throw distance, which provides flexibility in projector placement and enables teachers, lecturers, and business professionals to display large images in classrooms, conference rooms, and other moderately sized presentation environments. The Canon LV-7365 Multimedia Projector can display a full 100-inch picture (measured diagonally) from only 9.2 feet away. Another benefit of the Canon LV-7365 Multimedia Projector’s Genuine Canon Optics are the new multi-layer coatings on its 1.6x projection zoom lens, which minimize internal reflection, flare and ghosting while also increasing contrast. Outputting a full 3000 ANSI Lumens with a contrast ratio of 500:1, the Canon LV-7365 Multimedia Projector displays bright, crisp, full-color images for maximum presentation impact.
Further enhancing the quality of the pictures from the Canon LV-7365 Multimedia Projector projects is its DVI-I interface, which provides an all-digital connection between the projector and digital input sources, such as DVD players and PC’s. The DVI-I interface maintains high signal integrity and avoids the signal-conversion step required by an analog RGB interface. The DVI-I interface provides a clearer picture with no flickering, blurred lines, ghost images or coloration artifacts with text display, an important benefit when projecting spread sheets, technical diagrams or Web pages.
In addition to its DVI-I interface, the Canon LV-7365 Multimedia Projector includes other advanced features usually found only on high-end models. These user-friendly innovations are designed to assist teachers, business professionals, and others for whom presentations are not a primary occupation. Innovations include 5W Built-in Speakers, Quick Start/Quick Cooling, Enhanced Wall Color Correction, Flexible Image Settings, and an advanced (but simple-to-use) onscreen Control Panel, which is adjustable using buttons on the top of the Canon LV-7365 Multimedia Projector or with a wireless remote with matching icons.
Weighing only 7.3 lbs., the new Canon LV-7365 Multimedia Projector is a compact, highly portable, fully featured presentation solution. It is scheduled to be available in mid-November at a manufacturer’s suggested list price of $1,499.00*.
For more information, visit www.canonprojectors.com.
About Canon U.S.A., Inc.
Canon U.S.A., Inc. delivers consumer, business-to-business, and industrial imaging solutions. Its parent company, Canon Inc. (NYSE:CAJ), a top patent holder of technology, ranking third overall in the U.S. in 2006**, with global revenues of $34.9 billion, is listed as one of Fortune’s Most Admired Companies in America and is on the 2007 BusinessWeek list of “Top 100 Brands.”
All referenced product names, and other marks, are trademarks of their respective owners.
Specifications and availability are subject to change without notice.
* Pricing subject to change at any time. Actual prices are determined by individual dealers and may vary.
** IFI Patent Intelligence, January 2007.
