Canon imageFORMULA DR-M160II Scanner
Canon imageFORMULA DR-M160II scanner
Canon just introduced the imageFORMULA DR-M160II office document scanner, which offers speeds up to 60 pages-per-minute (PPM) and the ability to scan both sides of a document in a single pass. The imageFORMULA DR-M160II can help workgroups large and small quickly translate their paper-based information into digital data that is easily searched, stored, and shared.
The imageFORMULA DR-M160II scanner is equipped with additional features that help improve legibility, mixed-batch scanning and data searching. For hard-to-capture documents, such as hand written notes or receipts, Character Emphasis will pull through the text or image so the information is clear and easy to read. The Auto Resolution feature automatically adjusts the output resolution of mixed batches of documents and photographs to improve image quality while reducing the file size for easy storage. With Optical Character Recognition, scanned documents are converted into digital content that can be edited and searched.
An upgrade to Kofax Virtual ReScan (VRS) Elite is also included with the DR-M160II scanner at no additional charge. Kofax VRS Elite reduces the time involved in manual document preparation and enhances the quality of scanned images, dramatically improving both manual scanning productivity and the efficiency of document capture processes. It can automatically examine documents and apply the correct settings to deliver high-quality scanned images.
The imageFORMULA DR-M160II scanner includes bundled Canon and third-party software applications that simplify document scanning and information distribution, maximize image quality and scanner performance, share information directly from the scanner with cloud applications such as Microsoft SharePoint, and easily create and edit PDF files.
The imageFORMULA DR-M160II scanner is equipped to reliably handle a variety of documents – from large, oversized papers to embossed plastic cards. The DR-M160II delivers exceptional handling performance thanks to a new roller system designed to help ensure more unattended and seamless scanning.
Pricing and Availability
The Canon imageFORMULA DR-M160II scanner is available now for $1,195.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
