MFP
Canon imageCLASS MF4450 Laser Multifunction Printer
Canon announced the imageCLASS MF4450 Black and White Laser Multifunction Printer providing small or home office users easy-to-use, high-performance printing with advanced features necessary to tackle the daily, document output needs of businesses.
Canon's imageCLASS MF4450 tackles black-and-white laser printing and copying tasks at speeds of up to 24 pages-per-minute (ppm)I with fast-first print times of approximately six seconds. Crisp text and images can be produced at an enhanced print resolution of up to 1200 x 600 dpi quality. The imageCLASS MF4450 is equipped with a 250-sheet front-loading paper cassette that blends seamlessly into the unit, while the 35-sheet automatic document feeder works for both copying as well as scanning. Combining the high optical color scanning resolution of 600 x 600 dpi with a 24-bit depth produces exceptional quality for the end-user.
Canon's imageCLASS MF4450 is compact and user-friendly with an easy to navigate five-line LCD. An added advantage is the Push/Pull Scanning feature providing businesses with the flexibility of initiating a scan from a PC or directly from the device, increasing convenience and saving time. Additionally, minimal maintenance is required with Canon's Single Cartridge System, which combines the toner and drum in one easy-to-replace unit, resulting in excellent image quality retention and eliminating the complication and warehousing of separate toner and drum consumables.
Price and Availability
The Canon imageCLASS MF4450 will be available in early March 2011 for $249.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
