Camera Lenses
Canon EF 8-15mm f/4L Fisheye USM Lens
With its unique focal length range, the EF 8-15mm f/4L USM is the world's widest fisheye zoom lens. It delivers 180 diagonal angle of view images for all EOS SLR cameras with imaging formats ranging from full-frame to APS-C, and provides 180° circular fisheye images for full-frame EOS models. Professional photographers and cinematographers will revel in the unique perspectives afforded to them through this lens, particularly when coupled with the highly popular full-frame EOS 5D Mark II DSLR camera. Canon's new Fisheye zoom lens features both UD and aspherical lens elements to enhance image quality and is equipped with rubber gaskets and seals to enhance weather resistance. Canon's proprietary SWC (Sub Wavelength Structure Coating) is used to minimize flare and a new fluorine anti-smear coating is applied to the front and rear elements to make lens cleaning easier than ever.
The Canon EF 8-15mm f/4L Fisheye USM lens is expected to be available in January of 2011 for an approximate retail price of $1,400.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
