Cambridge Audio Minx Air 100 and 200 Wireless Speakers
Cambridge Audio today introduced Minx Air 100 and 200, the first wireless speaker systems to offer AirPlay, Bluetooth and Internet Radio. The sound is driven by MaxxAudio technology by Waves Audio, designed to deliver maximum possible detail from stored tracks and streaming services. Patented BMR (Balanced Mode Radiator) speakers create a rich sound that’s more room-filling than similar-sized traditional speakers. BMR’s unique, hybrid design of pistonic and flat panel technology ensures you never have to find the “sweet spot” to enjoy your music.  Meanwhile, a custom-developed digital amplifier guarantees heart-thumping performance, even at top volumes.
Minx Air 2
Minx Air also features sophisticated Digital Signal Processing (DSP) using advanced algorithms developed for music and movie production by Waves Audio. This not only allows Cambridge Audio to get the biggest sound possible from Minx Air’s compact enclosure, but delivers an experience that’s louder, crisper and fuller than other portable systems.
Minx Air’s sleek, contemporary case doesn’t just look great, it’s also solidly built to acoustically optimise the sound and eliminate distortion. Even the carrying handle stealthily acts as a bass port to improve deeper notes.  Created to blend seamlessly with its environment rather than take over, Minx Air’s organically contoured design is one of simplicity and subtlety. Its white lacquered, scratch resistant cabinet is complemented by ergonomic, soft-touch controls and is sure to look the part in any living space.
Minx Air 3
Using Apple’s AirPlay wireless system, Minx Air will simply connect to your iPhone, iPad or iPod Touch, as well as computers running iTunes.  However, Minx Air isn’t just aimed at owners of Apple devices, it instantly connects with any Bluetooth enabled phone, tablet or computer so everyone can share their music, regardless of make or model.
For radio enthusiasts Minx Air also features integrated favorite internet radio buttons for easy access at the touch of a button. For those looking to discover new stations, the Minx Air app – for Apple or Android – opens up access to 20,000 tried and tested stations from around the world. Once presets are saved on one smartphone or tablet, they’ll also be available to other devices with the Minx Air app installed.
Minx Air App
The Minx Air app offers way more than preset control and allows volume adjustment, bass control and access to a range of EQ settings to tailor Minx Air’s sound for any room. It also contains a tutorial for easy installation as well as step-by-step videos to simplify everyone’s set-up experience, whatever device they’re connecting.  And to ensure everyone can access Minx Air with ease, Cambridge Audio includes a remote that controls of power, presets, volume and bass.  But it’s not just about streaming, both Minx Air systems also have direct connections on the back so you can hook up your TV or Blu-ray player and make the most of Cambridge Audio’s legendary audio performance.
Minx Air 4
In more depth…
  • Minx Air 100 – Ideal for kitchens, bedrooms and living spaces, Minx Air 100 packs a punch with 100W of power from a cabinet just 14” wide
  • Minx Air 200 – Easily filling the largest rooms with crystal clear audio, Minx 200 boasts a 200W set of digital amplifiers, plus a built-in active 6.5” subwoofer offers a supercharged audio experience still only measures a modest 18” wide
  • AirPlay connection – Apple’s wi-fi streaming technology means you can play high-quality audio from your iPhone, iPad or iTunes simply and wirelessly
  • Bluetooth connectivity (and enhanced Bluetooth) – Stereo Bluetooth is found in all tablets, smartphones and nearly every laptop or MacBook. Minx Air supports the Standard Bluetooth CODEC (SBC) as well as two superior sounding formats which many of today’s devices natively support:
    • AAC – Minx Air also works with AAC audio files via Bluetooth for the very best quality audio
    • apt-X – Minx Air’s apt-X technology allows CD-quality over Bluetooth from devices featuring apt-X support
  • Audio quality – Minx Air features a wealth of audiophile technologies including:
    • High efficiency digital amplifiers for maximum power
    • Digital Signal Processing (DSP) – Minx Air’s 24-bit DSP runs processors featuring MaxxAudio technology, which dramatically enhances audio performance. MaxxAudio is developed by Waves Audio, recipient of a Technical GRAMMY award. Waves audio enhancements are used in top recording and mastering studios and are featured on hit records, major motion pictures and video games.
    • Patented BMR (Balanced Mode Radiator) speaker drivers for a wider, more room-filling sound than similar-sized traditional speakers
  • Internet radio – Use the Minx Air iOS and Android apps to find favourite stations, then assign them to 5 preset buttons on the Minx Air unit for instant access without the app. Or use the Minx Air app to discover new stations from around the world – by location, genre or minimum bitrate from a database of 20,000 tried and tested stations
  • Streaming services – Use your smartphone, tablet or computer to enjoy Spotify, Pandora and other services in hi-fi quality
  • Wired connections – RCA analogue stereo in means you can also plug your TV, Blu-ray player or other home entertainment devices easily in to Minx Air to experience its superb sound quality – far superior to modern flatscreen TV speakers
  • Minx Air App – Custom developed apps for iPhone, iPad (iOS) and Android devices offer the ultimate in control. Access 10 radio presets, volume control, bass and EQ settings. The app includes a comprehensive set-up tutorial and links to a series of step-by-step videos. It can also be used to configure first time network connection
  • Simple set-up for every home – A series of intuitive videos (also available online as well as via the Minx Air app) and a Quick Start Guide, explains how to connect Minx Air to a network in seconds. Alternatively, use the built-in ethernet socket for plug-and-play connection or connect without a home network using Bluetooth
  • Acoustically damped construction – Minx Air’s discreet design conceals a wealth of features designed to maximise its audio potential. Finished in scratch resistant high gloss lacquer, the acoustically damped cabinet is designed to eliminate vibration and distortion – even at high volumes. Cleverly, it incorporates a bass port within the carry handle
  • Eco-friendly – <0.5W standby power consumption and Auto Power-Down feature
Price and Availability
The Minx Air 100 and 200 are available direct from www.cambridgeaudio.com or from Cambridge Audio specialists for $449.00 and $599.00 respectively.
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
In 2025, the best-in-class streamers from Cambridge, Bluesound and WiiM set the pace as new challengers from FiiO, Topping, and Eversolo loom for 2026.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
New Cambridge Audio firmware update enables Amazon Music streaming, a 7-band EQ, and room compensation on the company's latest streamers at no extra charge.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Cambridge Audio StreamMagic Gen 4 now supports Qobuz Connect, delivering seamless high-res streaming with full app control and pristine 24-bit/192kHz audio.
Cambridge Audio supports Spotify Lossless, JLab debuts JBuds Open & Epic Pods, and Nothing unveils its sleek Ear (3) earbuds.
The Cambridge Audio Melomania Touch was already an excellent true wireless IEM -- this new app update makes it even better.
The Cambridge Audio Melomania A100 delivers hi-fi sound, advanced ANC, and top-tier codecs like LDAC for $149—challenging AirPods Pro 2 and SoundPEATS with premium...
