Cambridge Audio Announces Melomania Touch Wireless Earphones
Sleek true wireless earbuds feature EQ customizations via app and a High Performance Sound Mode for audiophiles on-the-go.
Cambridge Audio Melomania Touch True Wireless Earphones in white worn on woman
British audiophile brand Cambridge Audio today announced a new true wireless earphone called the Melomania Touch. Set to arrive January 1st 2021 with a price of $149.95, Cambridge Audio’s latest earbuds come in an all-new sleek design with touch controls, while boasting a sonic upgrade and longer battery life over the prior generation Melomania 1 (now discounted to $79.95 at Amazon).
All-new Design
cambridge-audio-melomania-touch-earphones-black-3q
cambridge-audio-melomania-touch-earphones-black-rear-grill
Audio Features
Sound from the Melomania Touch is generated from custom Cambridge Audio 7mm drivers enhanced with graphene for improved dynamism and response. An innovative High Performance Audio Mode uses proprietary hi-fi grade amplification technology that the company claims delivers a genuine step forward in sonic performance — offering even greater soundstage, lower noise and a higher dynamic range. The only downside is that it eats up battery life, resulting in 7 hours of continued use instead of 9 hours.
Transparency Mode is another new feature, which feeds in outside ambient noises so you can be aware of your surroundings while still enjoying music at the same time. You can turn the Transparency Mode on or off using touch controls on the earbuds, and adjust the transparency levels within the Melomania app.
Additionally, the inclusion of two high quality microphones and Qualcomm’s Clear Voice Capture (cVc) noise-cancelling technology ensures that voice calls over smartphones, tablets and laptops remain crisp, clear and free from background noise.
App Customizations
cambridge-audio-melomania-touch-ios-app
The new Melomania app, compatible with iOS and Android devices, enhances the experience of using Melomania Touch. With the free app, you can customize EQ settings and tailor music playback to your individual sonic style, locate misplaced earbuds using your phone’s map location, and check each earbud’s battery life. The app also allows you to upgrade Melomania Touch’s firmware, which means the product is future-proofed and will improve over time.
cambridge-audio-melomania-touch-earphones-black-next-to-case
Convenience
Using intuitive touch controls on Melomania Touch, simply tap on the earbuds to play and pause music, skip tracks, change volume, take hands-free calls, switch on Transparency Mode and summon Siri or Google Assistant.
With IPX4 certification, Melomania Touch is also protected against water and sweat, so the headphones can withstand a sudden spell of rain or your daily exercise.
Melomania Touch also comes with a new compact charging case finished in premium microfiber leather and sports a fast-charging USB-C port.
cambridge-audio-melomania-touch-earphones-white-with-case
Comparison
Melomania 1Melomania Touch
MSRP$99.95$149.95
Bluetooth5.0, Class 25.0, Class 2
Qualcomm ChipQCC3026QCC3020
Driver5.8mm7mm
Microphone Sensitivity96dB SPL at 1kHz 100dB SPL at 1kHz
Battery (per charge)9 Hours9 Hours
Battery (total)45 Hours50 Hours
Touch ControlsYesYes
High Performance ModeYes
Transparency ModeYes
Low Power ModeYes
App/EQ CustomizationsYes
CertificationIPX5IPX4
ChargingMicro USBUSB-C
Weight4.6g5.9g
Price & Availability
The Cambridge Audio Melomania Touch true wireless earphones will be available January 1, 2021 in black or white for $149.95 at Amazon and cambridgeaudio.com.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
With enhanced adaptive noise cancellation and a new driver design, Technics latest True Wireless Earbuds will give Bose, Sony and Sennheiser a run for...
