Cambridge Audio today introduced the Melomania 1+ true wireless headphones for $139.95. These Bluetooth earbuds improve upon Melomania 1 (without the plus), adding app control, customizable EQ settings and an innovative High Performance Audio Mode. The earbuds also now feature USB-C fast charging and include more memory foam ear tips for greater comfort and secure fit.
Cambridge Audio Melomania 1+ earbuds are built for daily use, with a super lightweight design that offers a seamless experience whether you’re listening to your favorite playlist, enjoying some time away from a noisy home, or going on your daily run.
With each earbud weighing just 4.6g and IPX5 certification protecting them against rain and sweat, the headphones can be worn for hours on end throughout the day.
Now including both medium and large size memory foam ear tips to ensure a secure fit, Melomania 1+ comes with multiple ear tip options which offer the perfect combination of excellent noise isolation, a comfortable fit, and better sound quality overall.
Long-lasting battery life
Charging the Melomania 1+ earbuds is now quicker than ever thanks to the inclusion of USB-C on the charging case. This makes it easy to top up the earbuds’ battery level when you’re on the move – meaning you’ll never be without music for too long.
Melomania 1+ has nine hours of battery life on a single earbud charge, while the charging case offers four times that. This results in an incredible 45 hours of total playtime.
Customize your sonic style
Melomania 1+ is compatible with the new Melomania app, letting you unlock valuable new features. With the free app, you can customize EQ settings to your heart’s content, personalizing the sound of Melomania 1+ to suit your musical taste.
Through the Melomania app – available for iOS and Android devices – users can also check the battery level of each earbud, locate misplaced earbuds on a map, and receive firmware updates to take advantage of future user experience improvements.
Design
Inside the Melomania 1+ earbuds are 5.8mm graphene-enhanced drivers, graphene being a lightweight material chosen by Cambridge Audio’s engineers for its incredible strength and rigidity. These qualities give the headphones their dynamism and response, achieving the immersive performance that Melomania headphones are renowned for.
The Melomania 1+ earphones also now benefit from the inclusion of Cambridge Audio’s ground-breaking High Performance Audio Mode, a world-first in wireless in-ear headphones that uses the same hi-fi grade amplification found in the company’s renowned CX range of stereo amplifiers. This default sound mode ensures the Melomania 1+ earbuds offer a higher dynamic range, a wider soundstage, and lower noise levels than before. It’s a high level of audio fidelity that Cambridge Audio claims is unheard of at this price point.
The true wireless design features Bluetooth 5.0 technology and supports AAC and aptX codecs – meaning smartphone users can stream high-quality wireless audio without signal drops.
Price & Availability
The Cambridge Audio Melomania 1+ comes in black or a new white finish, and is available to purchase directly from Cambridge Audio and Amazon, priced at £119.95 / €129.95 / $139.95.
Melomania Comparison
Melomania 1 | Melomania 1+ | Melomania Touch | |
MSRP | $99.95 | $139.95 | $149.95 |
Bluetooth Version | 5.0 | 5.0 | 5.0 |
Codec Support | SBC / AAC/ aptX | SBC / AAC/ aptX | SBC / AAC/ aptX |
True Wireless Stereo Plus | – | Yes | Yes |
Driver Type | 5.8mm Graphene-enhanced | 5.8mm Graphene-enhanced | 7mm Graphene-enhanced |
USB Charging | Micro USB | USB-C | USB-C |
Ear Tips | S/M/L Silicone / Foam | S/M/L Silicone / Comply™ / Foam | S/M/L Silicone |
Battery Life | 45 hrs (9+36) | 45 hrs (9+36) | Up to 50 hrs (9+41)* |
Works With Voice Assistants | Yes | Yes | Yes |
Colors | Black / Stone | Black / White | Black / White |
App Support | – | Yes | Yes |
Long Play Mode | – | Yes | Yes |
Transparency Mode | – | Yes | Yes |
EQ Settings | – | Yes | Yes |
Find My Earphones | – | Yes | Yes |
Adjustable Fins | – | – | S/M/L |
On-Earphone Control | Push Button | Push Button | Touch Button |
Interchangeable Covers | – | – | Yes |
Premium Microfibre Leather Finished Case | – | – | Yes |
Case Dimensions | 59 x 50 x 22mm | 59 x 50 x 22mm | 30 x 72 x 44mm |
* In Long Play mode
