Cambridge Audio Announces Flagship DacMagic 200M with Native MQA
Feature packed $499 DAC and Headphone Amplifier adds native MQA support and processes hi-res audio up to 32-bit/768kHz (PCM) and DSD512.
Cambridge Audio DacMagic 200m DAC Headphone Amplifier Front Angle
British audio specialists Cambridge Audio, today announced their new top-of-the-range DAC (digital-to-analog converter) and headphone amplifier called the DacMagic 200M. The $499 hi-fi component is designed to improve the sonic performance from your favorite digital music streaming devices or CD players.
Now with native MQA support, integrated Bluetooth, a more powerful headphone output and superior DAC technology, the DacMagic 200M provides a step up from the previous generation DacMagic Plus. The 200M offers new high-quality DACs that can handle PCM and DSD signal inputs at a higher resolution than before – up to 32-bit/768kHz (PCM) and DSD512 natively.
Dual ESS Sabre DACs are at the heart of the DacMagic 200M. Its dual mono configuration means each DAC processes the left and right channels separately, which is said to provide better performance. Switchable digital filters on the DacMagic 200M offer greater flexibility and control over your listening experience. These three pre-set filters help reduce noise generated by the digital-to- analog conversion process, with each filter offering a different sonic option depending on the source material.
Native MQA support
The DacMagic 200M is Cambridge Audio’s first product to natively support MQA files.
MQA is an award-winning British technology that not only captures every fine detail of a recording but also makes it easy to stream online. TIDAL music streaming service, for example, uses MQA technology to deliver master quality sound. The goal of MQA is to be able to stream hi-res music that sounds closest to the original studio recording.
The DacMagic 200M makes it easy to know when you’re listening to MQA files: the LEDs on the front panel will light up when MQA encoded files are detected.
Headphone Amplifier
The DacMagic 200M can also be used to improve a headphone listening experience. It’s high-quality headphone amplifier with a 6.3mm output with reduced impedance. Cambridge Audio claims this delivers more power, less distortion, less noise and tighter audio control when listening via headphones.
Cambridge Audio DacMagic 200m DAC Headphone Amplifier Back
Compact Design
The DacMagic 200M is encased in a beautifully built, steel and aluminum box with Lunar Grey finish. Multiple digital inputs (two coaxial, two optical, one USB type-B) allows you to plug in any number of digital sources – including laptops, CD players, games consoles and Blu-ray players. Plus it has both balanced and unbalanced analog connections for connecting to all types of existing audio systems. For added convenience, integrated Bluetooth with aptX support makes it easy to stream music wirelessly from smartphones or tablets.
Price & Availability
The Cambridge Audio DacMagic 200M will be available for £449 / $499 / €499 in February 2021 at CambridgeAudio.com and select US retailers.
Update: Checkout our exclusive Cambridge Audio DacMagic 200M review.
Specifications
  • Dual ESS Sabre DACs
  • Native MQA and DSD Support
  • 6.3mm Headphone Output
  • 3 x Pre-set Digital Filters: Fast, Slow, Short Delay (Selectable)
  • Integrated Bluetooth Input: Bluetooth 5.0, aptX, AAC, SBC
  • Digital Inputs (optical, coaxial, USB Type-B)
  • Balanced and Unbalanced Analog Outputs
  • Max file resolutions supported: 12-bit/96kHz (optical); 24-bit/192kHz (coaxial); 32-bit/768kHz, DSD512 (USB)
  • Finish: Lunar Grey
  • Dimensions (hwd): 52 x 215 x 191mm
  • Weight: 1.2kg
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Does full EQ functionality and even more power make the Element IV an easy recommendation at $549?
DAPs
At $2,299, Astell&Kern found a few ways to maintain flagship audiophile DAP performance at a lower cost. Find out what's changed.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
At $1,300, is the STAX SRM-400S capable of driving some of the best headphones in the world?
At $1,999, Orchard Audio Valencia is a balanced desktop power amplifier designed for headphones, but powerful enough for speakers.
FiiO expands its line-up with K17 Headphone Amp, which provides a lot of features and connectivity that raise the price, but should please any...
