Cabasse’s Rialto Wireless Loudspeakers Might Be A Better Option For Your Desktop or TV
The Cabasse RIALTO Powered Speakers offer Bluetooth, HDMI-ARC, and network connectivity for $3,000.
Cabasse Rialto Desktop Speakers Black Lifestyle
Cabasse, an iconic French brand in the Hi-Fi market with an international following, has released the RIALTO, their first wireless-powered speakers with a bookshelf form factor.
The RIALTO has an elegant look while delivering an optimal listening experience for music and TV listening.
Cabasse Rialto Speakers (white) with TV
Cabasse RIALTO Overview
The Cabasse RIALTO system consists of two powered speakers that are linked together. One speaker is designated as the primary speaker and the other is the secondary speaker.
Both speakers include built-in amplifiers and are required to be connected to AC power. However, there is no need to connect the speakers to an additional amplifier, stereo, or home theater receiver. The primary speaker includes a selection of audio input connections as well as a Bluetooth antenna. Audio signals can be transferred from the primary to the secondary speaker via Ethernet or Digital Optical connection link.
Key Features
Coaxial Speaker Design: Three speakers are placed on the same axis. This technology, developed by Cabasse allows all sound waves to spread out from a single source point so that they travel coherently and naturally, without interference and artificial coloring of the sound.
HELD: High Excursion Low Distortion woofers enable the RIALTO to deliver powerful, deep,  accurate, and distortion-free bass.
DEAP (Digital Enhancements Acoustical Interface): This technology enhances the performance of the loudspeakers via a dynamic multi-band signal processing with feedback loops that allow to exploit all the available amplification power for a distortion-free rendering of the “peaks”.
Built-in Sound Calibration: Utilizing a built-in microphone, the RIALTO provides automatic room calibration. Also, the Cabasse Stream CONTROL app, provides additional listening personalization via optimization tools developed to fit users’ room environments and preferences.
Cabasse Rialto Desktop Speakers White Lifestyle
HDMI-eARC: HDMI-eARC allows you to listen to TV sound and also control the volume of the RIALTO using the TV’s remote control. This makes the RIALTO a great soundbar alternative.
USB Input:  This allows playback of digital audio files via flash drives or other compatible devices. Compatible formats include MP3, AAC, WMA, AIFF, FLAC, ALAC, Ogg Vorbis, DSD 64/128, and WMA lossless
Bluetooth: The Bluetooth receiver supports aptX allowing for “CD-quality” audio streaming from compatible smartphones, tablets, and computers. Using Bluetooth, you can stream from compatible platforms.
Streaming Services: Qobuz, Deezer, TIDAL, Spotify, Web Radio, Napster
Touch Screen Control: The primary speaker includes an easy-to-use touch screen for volume/mute, input selection, and playback control. The color LCD video screen also displays album covers for the music being played.
Cabasse Rialto Touchscreen Control
StreamControl App: In addition to the onboard Touch Screen Control, Cabasse also provides access to its StreamControl App for iOS and Android.
Voice Control: According to Cabasse, the RIALTO also works with Google Assistant.
Cabasse Stream Control App
Specifications
  • Model: RIALTO
  • Speaker Type: Powered Wireless Speakers with 3-Way Amplification
  • Amplifier Type: Class D
  • Amplifier Power (RMS x2)
  • HF: 300 watts
  • Midrange: 300 watts
  • Woofer: 450 watts
  • Tweeter/Midrange (each speaker): 1 13cm coaxial BCI
  • Woofer (each speaker): 1 17cm HELD (High-Excursion/Low Distortion)
  • Frequency Response: 30 to 27,000 Hz
  • THD+N (Total Harmonic Distortion + Noise):  0.005% (1W, 4Ohm)
  • Maximum System Output (SPL):121 dB
  • Dimensions (HLP) for Each Speaker): 260 x 206 x 239 mm (10.2 x 8.1 x 9.4 inches)
  • Tip: H = Height, L = Length, P = Width
  • Weight: 15.2 Kg
  • Finishes: White, Satin Black
Cabasse Rialto Back Panel Primary
Wired Connections
Tip: If you want to connect a turntable the RIALTO, the turntable either has to have a built-in phono preamp or an external phono preamp would need to be placed between the turntable and RIALTO’s analog line-in.
Wireless Connections
  • Bluetooth (aptX)
  • Wi-Fi
Tip: The RIALTO can be combined with other Cabasse wireless speakers via network connectivity.
Included Accessories
  • Power cord (2)
  • Protection cover (2)
  • HDMI cable
  • Optical cable
  • Installation guide
Availability & Pricing
The Cabasse RIALTO wireless powered speaker system is available for $2,980.00 (US) through authorized Cabasse distributors/dealers.
Monoprice’s Monolith MTM-100 Powered Speakers Will Dominate Your Desktop
Edifier R1700BTs Wireless Speakers: Review
PSB’s Alpha IQ Powered Loudspeakers Are Finally Here: CEDIA 2022
ELAC Debut ConneX Powered Loudspeakers: Just Add A Turntable
SVS Announces Prime Wireless Pro Powered Speakers
KEF LSX II Wireless Loudspeaker Unveiled: Are Passive Loudspeakers Becoming Obsolete?
KEF LS60 Wireless Loudspeaker Unveiled
Best Affordable Wireless Speakers: 2022 Buying Guide
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
The updated Bowers & Wilkins Pi7 S2 and Pi5 S2 True Wireless Earphones featured longer battery life, upgraded drivers, and superior sound quality.
Dan Mackta of Qobuz answers questions on Reddit on AI, Linux support, app features, and future platform growth.
At $329, WiiM Ultra is the company's top-of-the-line digital music streamer which adds a touchscreen, HDMI ARC and a subwoofer out.
Dongle DACs
Is the $49 Creative BT-W6 Bluetooth 5.4 dongle worth it to give your old laptop or console aptX Adaptive, LC3, and 24-bit/96kHz wireless audio?
The new Qobuz Android TV App lets you stream or download lossless and hi-res digital music from select Sony, TCL and Hisense TVs.
Coming early 2025, Marantz previews two modern luxury wireless speakers featuring unique technology, priced at $3,500 and $5,500.
The Triangle CAPELLA 2 delivers flexible home audio with WiSA wireless, Bluetooth, and multiple wired inputs, including a new subwoofer output, combining French design...
At $999/pair KEF’s Coda W wireless speakers feature Uni-Q drivers, built-in amps, MM phono preamp, and aptX Lossless, but lack support for AirPlay 2...
