Cabasse’s Pearl Myuki Wireless Speakers Might Raise A Few Eyebrows in Paris: High End Munich 2024
Cabasse expands its Pearl Collection with a 200-watt portable wireless speaker that’s just over 7-inches around and plays up to 109 dB.
Cabasse Pearl Myuki Wireless Speakers in Black and White
Six years after launching the first connected speaker from The Pearl Collection, French speaker maker Cabasse is adding the Pearl Myuki to its line-up.
The Pearl Myuki is a new portable, battery-powered, connected, ultra-compact, high-resolution active speaker being shown at High-End Munich 2024.
With a visually innovative spherical shape and compact size, the Myuki is designed to deliver sound that is both balanced and powerful. The built-in speaker system is capable of producing up to 109 dB SPL in stereo mode.
The drivers include a Dome 45 wideband speaker and two high-12 cm bass drivers arranged in a Push-Push layout, operating within a very compact enclosure. The drivers are equipped with honeycomb-structured membranes, ensuring precise, firm, and tight bass.
Cabasse Pearl Myuki Speaker White
Practical Design
The spherical Pearl Myuki speaker integrates into any interior decor. It’s available in matte black or matte white finishes with chrome bezels and details in black or silver. Additionally, its woofers feature an embossed Lissajous pattern, adding a touch of sophistication to its aesthetic appeal.
With a diameter of 17 cm (6.7 inches) and weighing approximately 2 kilograms (4 lbs 10 oz), the Pearl Myuki comes with a handle that enables the speaker to be easily moved from room to room. For outdoor use, the included custom-made bag allows for hand or shoulder carrying.
Tip: The Pearl Myuki can be mounted on the wall using a compatible Cabasse wall bracket
Cabasse Pearl Myuki Speaker Black Top
Core Features
Targeted for those looking for quality sound at home or on the go, the Pearl Myuki incorporates technologies found in high-end Cabasse systems.
Hi-Res: High-resolution audio streaming from supported sources,
DFE adjustment: This optimizes the audio spectrum in real-time based on the listening level, spectral content, and dynamics of the music)
Automatic CRCS room calibration: This feature optimizes sound within your space and tonal spectrum adjustment.
Portability: An ultra-compact, portable, battery-powered high-resolution (HR) connected active speaker with exceptional usage life even at high power.
Battery Life: It boasts a 12-hour battery life, allowing cable-free use outdoors or on the move.
Smart Wi-Fi: Another innovative feature is its Smart WiFi capability, ensuring uninterrupted music playback when switching between WiFi networks (WiFi 5, 2.4, or Mesh).
Channel Configuration: With the Pearl Myuki, users can opt for mono or acquire two for stereo mode by pairing them, delivering a combined power of close to 200 watts RMS.
Onboard Controls: The Myuki features 6 illuminated LED tactile keys with discreet haptic feedback, making control effortless (source/play, pause/volume/power).
System Integration: Those that already own a Cabasse-connected speaker can integrate the Pearl Myuki into a current system for multi-room use in mono or stereo. It serves as an ideal complement in settings like kitchens, offices, or bedrooms, especially when paired with another Pearl speaker located elsewhere in the house.
Cabasse Pearl StreamCONTROL App Lifestyle
StreamCONTROL App
Cabasse-connected systems (such as the Pearl Myuki) can be paired and controlled via the StreamCONTROL App This provides multi-room playback of the same music in multiple rooms simultaneously, or different tracks in different rooms to Cabasse-connected speakers.
Music can be streamed from a Bluetooth® or an audio input to multi-room. It features hub-less HD streaming technology at 80 microseconds, and plays all audio files, from MP3 to ultra-high-definition files (stored at home on NAS drives or PCs, internet radio, or specialized services).
Physical Connectivity
The Pearl Myuki also provides comprehensive connectivity, enabling connection to a TV, turntable, CD player, or NAS via optical cable. It features an Ethernet port and a 3.5mm jack on the back, as well as the ability to play content from a USB/USB-C drive.
Specifications
  • Sound level (SPL): 103 dB peak mono, 109 dB peak stereo
  • Frequency Response: 30 – 23,000Hz
  • Medium-Tweeter: Dôme 45
  • Woofer: 2 x 12 cm (4.72 inches)
  • Wireless Connections: WiFi, Bluetooth
  • Wired Connections: Ethernet, 3.5 mm jack, USB-C, SPDIF optical
  • Digital Audio Formats: MP3, WAV, AAC, WMA, AIFF, FLAC, ALAC, Ogg, Vorbis, DSD 64/128, WMA lossless
  • Dimensions: 186 x 174 x 180 mm (7.32 x 6.85 x 7.1-inches)
  • Weight: 2.1 kg (4 lbs 10 oz)
Price & Availability
The Cabasse Pearl Myuki will be available in June 2024 through authorized dealers and distributors for €699. Availability and U.S. pricing is forthcoming.
Tip: A custom carrying bag is included in the price.
Continue reading more stories from HIGH-END Munich 2024
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
