Burmester x Robbe & Berking Team Up On Limited Edition Audio System for $331,000
This handcrafted, limited special edition high-end sound system includes silver-plating and the fine woods of the luxurious oak Bar Trolley.
Burmester x Robbe & Berking Limited Edition BC150 Loudspeaker
Burmester, known for its high-end audio products, and Robbe & Berking, masters of silver craftsmanship, have partnered to provide exclusive limited editions of specially selected Burmester products to celebrate the 150th anniversary of the prestigious silver manufacturer.
The Burmester products selected to mark this event are the BC150 Speaker, 111 Musiccenter, and 218 Power Amplifier
Design Concept
The Anniversary Limited Edition combines the expertise of both Burmester and Robbe & Berking to promote the history of traditional silver manufacturing and the Robbe & Berking boatyard in a unique symbiosis of design and craftsmanship.
BC150
Burmester x Robbe & Berking Limited Edition BC150 Loudspeaker Side
For the BC150 speakers, the implemented silver and wood combination gives the BC150 speaker anniversary edition added sophistication. Warm brown tones contrast with shimmering silver accents and an elegant champagne tone found in the frame construction. The speaker’s side panels are made from luxurious oak Bar Trolley, which are otherwise used in the restoration of historic luxury yachts by the Robbe & Berking Classics shipyard, lend the design a special nautical touch. Meanwhile the front baffle features a silver-plated relief specially developed for the anniversary—a tribute to the waveform of the Robbe & Berking design classic Belvedere.
Robbe & Berking’s finely crafted logo inlays adorn the entire side surface of the BC150 speaker, emphasizing the edition’s exclusivity.
Burmester x Robbe & Berking Limited Edition BC150 Loudspeaker Angle
Inside, the BC150 is identical to its non-limited edition version:
  • Speaker Type: Floostanding, 3-way, bass reflex
  • Tweeter: 2 x Air Motion Transformer (AMT)
  • Mid-range Driver: 18 cm Elliptic phase plug and voice coil
  • Woofer: 32 cm Sandwich cone and strong motor with dual magnets
  • Frequency Response: (+/- 3 dB): 34 Hz to 20000 Hz
  • Crossover Frequencies: 155 Hz / 1800 Hz
  • Sensitivity (at 2.83 V/1 m): 88.5 dB
  • Nominal Impedance: 3 ohms
  • Dimensions (WxHxD):
    • 309 x 1433 x 601 mm
    • 12.17 x 66.42 x 23.66 inches)
  • Weight: 180 kg (396 lbs)
111 Musiccenter
Burmester Musiccenter 111 Front
Burmester Musiccenter 111 Rear
For the 111 Musiccenter, Burmester has given it housing of fine champagne anodized aluminum. Additional design features include Silver-plated knobs and a gleaming silver stripe elegantly stretching across the surface. The limited edition elements provide a striking new look for the Musiccenter.
Here is a feature rundown of the 111 Musiccenter:
The 111 Musiccenter incorporates a music server, CD player, and CD ripper as well as a DAC and an analog pre-amplifier in one unit. The analog preamp section can also serve as a central control unit for any music system but needs to be connected to an external amplifier in order to power speakers.
  • Streaming: TIDAL, QOBUZ, IDAGIO, and Internet Radio
  • Analog Inputs: 3 x XLR
  • Digital Inputs: 3 RCA, 3 TOSLINK
  • Analog Outputs: 1 x XLR, 1 x RCA
  • Digital Outputs: 1 x RCA, 1x TOSLINK
  • Headphone Jack: 6.3 mm (1/4″)
  • Upsampling: Up to 96kHz/24-bit
  • Switchable to: 192kHz/24-bit
  • Remote Control: Yes
  • BurLink: Yes (BurLink is a proprietary connection that allows Burmester products to coordinate and connect with each other)
  • Burmester X-Amp 3: Yes
  • Remote Input / Output: 1 / 1
    • 455 x 199 x 408 mm
    • 17.91 x 7.83 x 16.06 inches
  • Weight: 27 kg (59.5 lbs)
218 Power Amplifier
Burmester Power Amplifier 218 Front
Burmester Power Amplifier 218 Rear
To round things out, the collection is completed by the 218 power amplifier, which has been given champagne-colored anodizing and silver-plated accents.
Here is a feature rundown of the 218 Power Amplifier.
  • Device type: Dual-channel power amplifier (symmetrical design, stereo or mono operation)
  • Output Power:
    • 2 Channels (IEC 62368-1) at 2 Ω: 400 W
    • 2 Channels (IEC 62368-1) at 4 Ω: 275 W
    • 2 Channels (IEC 62368-1) at 8 Ω: 165 W
  • Connections: Balanced input (stereo or mono bridge with adapter) unbalanced input via adapter (adapter supplied) DC input/output for remote ON/OFF Remote control (remote control is optionally available)
  • BurLink interface Loudspeaker outputs
    • 496 x 216 x 479 mm
    • 19.53 x 8.5 x 18.86 inches
  • Weight: 42 kg (92.7 lbs)
Burmester x Robbe & Berking Limited Edition BC150 Loudspeaker Angle Left
Pricing & Availability
For availability, contact a Burmester Authorized Distributor or Dealer. The complete Limited Edition Burmester x Robbe & Berking music system retails for $331,000 USD, with individual pricing as follows:
    Limited EditionRegular models
    BC150$210,000$150,000
    111 Musiccenter$65,000$55,000
    218 Power Amp$57,500$50,000
    Total$331,000$205,000
    For more information: burmester.de
    Related Reading
    Hisense XR10 High-end Lifestyle 4K Laser Projector
    With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
    Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
    Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
    Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
    Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
    LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
    LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
    DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
    DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
    Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
    Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
    Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
    Loudspeakers
    Bang & Olufsen bets big on Union Square’s comeback, opening its largest store in a San Francisco still digging out from years of crime...
    Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
    Bang & Olufsen turns 100 with the Beolab 90 Titan Edition—a $200,000+ statement in aluminum and ego that proves audiophile excess is alive and...
    Hi-Fi Components
    The Florida International Audio Expo is coming to Tampa Feb 20-22, 2026 at the Sheraton Tampa Brandon Hotel.
    Audio Group Denmark dominated T.H.E. Show New York 2025 in New Jersey, proving why Danish hi-fi now leads the world with breathtaking sound, bold...
    Frank Zappa’s 1978 Halloween concert ‘The Big One’ released in full for the first time in a 5CD super deluxe box set with rare...
    JBL unveils its new flagship 4369 Studio Monitors at the Tokyo International Audio Show for audiophiles and studios alike. Available Q1 2026, price TBA.
    Popori Acoustics Vitorla proves electrostatic loudspeakers can finally sound alive—and look like a sculpture while doing it. Hear them at Warsaw and Capital Audiofest...
