Buffalo WLAE-AG300N Nfiniti Wireless-N Dual Band Ethernet Converter, Access Point and Bridge
Buffalo Technology today announced the Nfiniti Wireless-N Dual Band Ethernet Converter, Access Point and Bridge WLAE-AG300N. It is a versatile multifunction dual-band solution that can uniquely be configured to operate in three different modes. When configured as an Ethernet converter, the WLAE-AG300N simultaneously connects up to two wired devices to a wireless network; ideal for multimedia devices like gaming consoles, DVRs, video streaming hardware, etc. Additionally, WLAE-AG300N can be configured as an access point to create a wireless network or two units can be used to create a dedicated, high-performance 11n bridge or repeater, great for video streaming and extending the range of wireless networks. The WLAE-AG300N chassis has been streamlined for easy installation into just about any environment and dual-band 802.11n ensures high-performance data rates, whichever mode you configure the product in.
WLAE-AG300N can connect any two wired devices, such as printers, gaming consoles or DVRs, to an existing wireless network. It can turn any wired network into a high speed 11n network, or two or more can used to wirelessly connect and extend the range of the wireless network. 802.11n dual band support allows maximum performance and compatibility providing interference free connectivity, great for wireless video streaming, gaming and other high performance uses.
Buffalo WLAE-AG300N Nfiniti Wireless-N Dual Band Ethernet Converter, Access Point and Bridge in Hand
Features
  • Designed to IEEE 802.11n specifications
  • Wi-Fi Certified to ensure compatibility with other certified devices
  • Creates IEEE 802.11n (2.4 GHz/5 GHz), 802.11g/b and 802.11a wireless networks
  • Wireless connections with bit rates up to 300 Mbps
  • Two built-in 10/100 Ports for up to two simultaneous connections
  • Push-button secure wireless connections with AOSS
  • Simple web browser configuration, no drivers needed
  • Can be moved from device to device without reconfiguration
  • Backward compatible with 802.11g, 802.11a, and 802.11b
  • Supports WPA2, WPA-PSK (TKIP, AES) and 128/64-bit WEP Security
  • For best performance, use with a Buffalo Nfiniti Wireless-N Router
  • Great for high-speed multimedia streaming or online gaming
Buffalo WLAE-AG300N Nfiniti Wireless-N Dual Band Ethernet Converter, Access Point and Bridge Plug
Pricing and Availability
The WLAE-AG300N will be available in August at $74.99 MSRP.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
