Hard Drives
Buffalo MiniStation Stealth Portable Hard Drive
Buffalo Technology today announced the MiniStation Stealth, a high performance portable storage solution in a remarkably compact and lightweight contemporary form.
The MiniStation Stealth is a compact portable hard drive that is USB powered so there are no additional cables to manage and no need for a separate power source. Simply plug the MiniStation Stealth into any available USB port on your PC or Mac computer and instantly add capacity or store files to take on the road.
The MiniStation Stealth includes Buffalo's multi-purpose utility suite designed to enhance Windows PC performance and user experience. It features TurboPC, a utility designed to enhance PC performance for up to 2X faster file transfers. Also included, Buffalo's Backup Utility protects your important files and documents by backing up your PCs to your Buffalo external hard drive and it provides an easy-to-use data restore function. Store, back up and transport your content instantly with plug and play connectivity.
Pricing and Availability
The MiniStation Stealth will be available November in the US market at estimated street prices of:
  • $74.99 for the 320 GB (HD-PCT320U2/B)
  • $89.99 for the 500 GB (HD-PCT500U2/B)
  • $104.99 for the 640 GB (HD-PCT640US/B)
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
