Buchardt’s SUB10 Subwoofer Will Be Available in June and Takes Up Very Little Space
The SUB10 is a versatile 10-inch subwoofer in a skinny rectangular box that’s only 6.3-inches deep for inconspicuous placement near a wall or under a couch.
Buchardt SUB10 Subwoofer White Lifestyle Horizontal
Denmark-based Buchardt Audio celebrated its 10th anniversary in 2023. We have reviewed and reported on two past offerings, the S400 and P300 bookshelf speakers. Over the last decade, Buchardt speakers have provided Hi-Fi enthusiasts with a great listening experience and the opportunity to save money by buying direct.
As part of their 10th anniversary, Buchardt announced the Anniversary 10 (aka A10) WiSA wireless loudspeakers.
The A10 carries on the Buchardt tradition of in-house cabinet production and speaker assembly.
Also, what Buchardt can’t do in-house they use partners located in Denmark. This allows Buchardt to pay attention to details that deliver high performance for its customers.
The Anniversary 10 offer low end response down to almost 28Hz depending on the size of your room and setup, but that has not stopped Buchardt from introducing a rather compact subwoofer that also offers WiSA wireless connectivity.
The SUB10 features a very powerful long-stroke 10” woofer that has been designed specifically for this exact enclosure and Hypex amplifier.
The subwoofer also carries WiSA for wireless use with their range of active speakers, as well as standard wired connections for passive systems.
It also features Bluetooth for app-controlled DSP functions like Room Correction, Manual EQ, variable LLE slider, and more.
Buchardt SUB10 Subwoofer White Lifestyle Vertical
Buchardt SUB10 Subwoofer White Lifestyle Under Couch
The only 6.3-inch (16 cm) slim design is ideal for near-wall placement both on its side, standing up, and even lying on its back if you have special application needs, like placing it under your couch.
Hypex Class D Amplifier
Combined with a state-of-the-art power supply, this power stage claims to deliver up to 1200-watts (peak) into the woofers voice coil, which is only possible due sophisticated DSP processing assuring all parts are always running at their maximum performance.
Buchardt SUB10 Subwoofer White Rear Angle
Specifications
AmplifierHypex 400 Watt RMS / 1200 Watt peak Class-D
DSP settings App controlled settings for Room correction and more
Woofer10″ Custom long stroke woofer.
Analog inputs2 x XLR & RCA
Satellite outputs2 x XLR & RCA
Digital inputsWiSA 24 bit / 96khz. Can be paired across brands on Dolby and DTS
Variable Phase and LevelYes, including variable distance setting for delay via app
Variable Low Pass Filter40-150hz or Flat to 1000hz
Frequency response20-300hz +/- 1dB
Cabinet19mm / 0.74″ MDF with reinforced woofer mounting
Measurements (h x w x d)490 x 320 x 160 mm
Input voltage100-240 Volts AC auto adjusting (EU, US, UK power cords incl.)
Weight14 kg (31 lbs)
Buchardt SUB10 Subwoofer Black
Buchardt SUB10 Subwoofer Rear Panel
Price & Availability
The Buchardt SUB10 is available for pre-order for €1,300 €1,150 with an expected June 2024 release date at which time price will revert to €1,300 ($1,400 USD). Pre-order pricing is also available now to U.S. destinations for $1,245 USD.
For more information: buchardtaudio.com
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
