Bryston to Demo High Powered Two-Channel System at CES 2008
Peterborough, Ontario January, 2008 –Bryston, LTD has announced that the internationally praised BCD-1 CD player will be used in a high powered two channel audio system at CES 2008. The CES demo system, located in the Sands/Venetian Bassano ballroom 2601, will also feature the BP26 preamplifier and a pair of 28B SST 1000-watt mono amplifiers driving THIEL CS 3.7 loudspeakers. Torus Power will provide the RM-20 AC line conditioner and surge protection for the system.
The Bryston BCD-1 CD player is hand built utilizing fully discrete Class-A analog circuitry and 192K/24Bit Crystal DAC’s, which employ a combination of several different conversion methods to optimize the processing. The Bryston BCD-1 CD Player also uses discreet operational amplifiers after the DAC instead of the commonly used integrated circuits, enabling Bryston engineers to exactly match the needs of the DAC and allow for a more robust output than IC-based amplifiers. The use of discrete devices also allows Bryston to select components with carefully matched input and output impedances based on specific in-circuit requirements. The BCD-1 has an MSRP of $2695 US.
The Bryston BP26 is another hand assembled component housed in a steel cabinet to shield against EMI. The BP26 uses an outboard power supply to further isolate any potential sources of noise. Buffered inputs deliver lower distortion and improved linearity, and a ground plane has been incorporated in the design to further reduce crosstalk and noise throughout the internal circuitry. Base price for the BP26 (with power supply) is $3895 US.
The Bryston 28B SST mono amplifiers deliver the delicacy of vacuum tube amplifiers along with the awesome power of a 1000 watt solid state design. The Bryston 28B-SST is a fully balanced-output amplifier, which has reduced THD and IMD to unprecedented low values, (typically 0.001% or less). The 28B-SST delivers a new degree of transparency, musicality and ease of listening. Superbly low noise floor, typically below — 115dB, yields absolute silence between notes for hauntingly realistic reproduction. The 28B SST’s are $8000 each US.
The Torus Power RM-20 AC line conditioner is a far cry from your average surge protector. The design objective behind the Torus power isolation units (PIU’s) was to provide a no-compromise AC power conditioning solution to improve audio/video equipment performance based on true isolation, as well as equipment protection based on non-MOV (metal oxide varistors) surge suppression technology. The Torus RM-20 delivers true isolation along with low source impedance and ample instantaneous current for todays most sophisticated and powerful audiophile amplifiers, home theater systems, and video playback equipment. The RM-20 has an MSRP of $3000.
Bryston and Torus components and new products will be on display at the Sands/Venetian Bassano ballroom 2601 with THIEL Loudspeakers and Cardas Cables.
Splurge Audio Video Hi-Fi Tech Gifts 2026
Although not new in 2023, the Bryston BHA-1 has become our favorite headphone amplifier under $2,500.
Bryston's BHA-1 has proved itself for over a decade and is one battle tested headphone amplifier I wish I had discovered sooner.
The audiophile-grade Bryston BP-19 is a fully balanced, stereo preamplifier designed for analog purists.
Configurable audiophile stereo preamp includes hi-res DAC, headphone amplifier, built-in streaming music player with optional phono stage and HDMI connectivity.
MartinLogan reQuest speakers from 1996 have been out of production for many years but are one of the best used electrostatic loudspeakers if you...
Hi-Fi Components
The venerable Canadian manufacturer has been acquired by Colquhoun Audio and joins Bryston and Axiom Loudspeakers under the family tent.
Bryston's new vintage amplifier restoration program can breathe new life into old Bryston amps. Priced from $400 to $1,000.
New Bryston CEO, James Tanner will manage operations and fortify relationships with A/V specialty dealers.
