Bryston D-130Z and D-250Z Hybrid Zone Amplifiers
Bryston, LTD has announced that the first two of four new 8-channel zone amplifiers will be shipping to dealers by October 1st, 2009. The Bryston D-Series D-130Z Hybrid and the D-250Z Hybrid have been in development and many dealers have expressed the need for a lightweight, high performance multi-channel amplifier for distributed audio and industrial applications such as bars and restaurants. Bryston uses the term “Hybrid” in reference to the combination of class D amplifier technology along with a Bryston engineered linear power supply design. “This is what our dealers have been asking for–a multi-channel solution built to Bryston standards,” said sales VP James Tanner. “Although the D-Series is lightweight, highly energy efficient, and cost-competitive with other multi-channel products, these amplifiers also feature input stages and power supplies designed by Bryston–these are world class audio products,” Tanner stated. The Bryston D-Series is a highly reliable amplifier solution with low heat emissions for tight space applications, such as the equipment racks and utility closets commonly found in restaurants, bars, and nightclubs. Unlike most competitive industrial amplifiers however, the D-Series carries on Bryston’s tradition of sonic excellence and durability.
Product Specifications:
D-130Z Hybrid Features:
  • Bryston engineered dual 650 watt linear power supplies
  • 8 independent channels at 130 watts each into 4 ohms and 90 watts at 8 ohms.
  • 4 stereo zones at 130 Watts per channel into 4 ohms.
  • All channels driven 130 watts per channel at 4 ohms.
  • Each individual zone bridgeable to 400 watts into 8 ohms
  • Level control on each channel
  • Each channel can select direct input (RCA), left bus only, right bus only or L+R (mono)
  • Stereo bus can be linked to other amplifiers
  • Each zone can be muted independently with 12-volt trigger
  • 12-volt trigger for amplifier on/off
  • Soft-Start circuit to prevent high power in-rush current
  • Gold plated 5-way speaker binding posts
  • 5 year warranty
  • Price $4,395.00 Suggested List US/Canadian
  • Dimensions: width 19″ X height 4.125″ (3.5″ without feet) X depth 16″ including connectors
D-250Z Hybrid Features:
  • Bryston engineered dual 850 watt linear power supplies
  • 8 independent channels at 250 watts each into 4 ohms and 150 watts at 8 ohms
  • 4 stereo zones at 250 Watts per channel into 4 ohms.
  • All channels driven 200 watts per channel at 4 ohms.
  • Each individual zone bridgeable to 800 watts into 8 ohms
  • Soft-Start circuit to prevent high power inrush current
  • 5 year warranty
  • Price $5,695.00 Suggested List US/Canadian
About Bryston: Bryston (www.bryston.com) first opened for business in 1962 as a manufacturer of blood analysis equipment, and was named (as an acronym) for its three founders, Tony Bauer, Stan Rybb, and John Stonborough. In 1968, NASA engineer John Russell, Sr. relocated himself and his family to Canada from the US and bought the company, where his son Chris set to work designing the first Bryston amplifier. The Pro 3 made its debut in 1973, and since that time, Bryston components have become legendary for their hand-assembled build quality, performance and reliability in both the pro audio and consumer audio market segments. Bryston amplifiers are utilized in some of the world’s most renowned recording studios and owned by many discerning music industry professionals. Bryston applies manufacturing techniques and materials in the everyday assembly of their electronic equipment that are more typically utilized by the military and aerospace industries. Bryston is now based in Peterborough, Ontario Canada, just northeast of Toronto, and sold through over 150 dealers in North America and 60 countries worldwide.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Although not new in 2023, the Bryston BHA-1 has become our favorite headphone amplifier under $2,500.
Bryston's BHA-1 has proved itself for over a decade and is one battle tested headphone amplifier I wish I had discovered sooner.
The audiophile-grade Bryston BP-19 is a fully balanced, stereo preamplifier designed for analog purists.
Configurable audiophile stereo preamp includes hi-res DAC, headphone amplifier, built-in streaming music player with optional phono stage and HDMI connectivity.
MartinLogan reQuest speakers from 1996 have been out of production for many years but are one of the best used electrostatic loudspeakers if you...
Hi-Fi Components
The venerable Canadian manufacturer has been acquired by Colquhoun Audio and joins Bryston and Axiom Loudspeakers under the family tent.
Bryston's new vintage amplifier restoration program can breathe new life into old Bryston amps. Priced from $400 to $1,000.
New Bryston CEO, James Tanner will manage operations and fortify relationships with A/V specialty dealers.
