Bryston BDP-1 Digital Music Player
Bryston LTD announced its BDP-1 digital music player built to to give music aficionados the ability to enjoy their library of high-resolution digital music files (resolutions of up to 24-bit/192kHz are supported) residing on a USB storage device, which in turn is directly connected via standard USB cable or thumb drive to the BDP-1 digital music player.
“The BDP-1's feature set is unique and we have found that it is most easily defined by clarifying what it does not do. The Bryston BDP-1 does not contain an internal DAC, a hard-drive, a streamer, a CD player/ripper, noisy fans or switching power supplies. The BDP-1 connects to an external DAC for playback through AES-EBU or BNC digital outputs. Quite simply, the BDP-1 is an ultra high-performance digital music player when connected to an external drive and DAC.”
— James Tanner, Bryston
Features
  • Out-of-the-box playability when connected to an external USB drive–no network required
  • Supports 16 and 24 bit files with sample rates of: 44.1 KHz, 48 KHz, 88.2 KHz, 96 KHz, 176.4 KHz & 192 KHz.
  • Linux operating system optimized to provide the highest quality audio performance
  • Industrial quality motherboard uses only a small fraction of its computing power to optimize sonic performance
  • Utilizes Bryston-modified top quality soundcard
  • AES-EBU Balanced and BNC (spdif) output section for the highest possible performance
  • Electronic isolation of audio components from computer components
  • Galvanic isolation employed to prevent charge-carrying particles from migrating section to section
  • Warranty on the BDP-1 is five years parts and labor
Price and Availability
MSRP is $2,150. Available Q4, 2010.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Although not new in 2023, the Bryston BHA-1 has become our favorite headphone amplifier under $2,500.
Bryston's BHA-1 has proved itself for over a decade and is one battle tested headphone amplifier I wish I had discovered sooner.
The audiophile-grade Bryston BP-19 is a fully balanced, stereo preamplifier designed for analog purists.
Configurable audiophile stereo preamp includes hi-res DAC, headphone amplifier, built-in streaming music player with optional phono stage and HDMI connectivity.
MartinLogan reQuest speakers from 1996 have been out of production for many years but are one of the best used electrostatic loudspeakers if you...
Hi-Fi Components
The venerable Canadian manufacturer has been acquired by Colquhoun Audio and joins Bryston and Axiom Loudspeakers under the family tent.
Bryston's new vintage amplifier restoration program can breathe new life into old Bryston amps. Priced from $400 to $1,000.
New Bryston CEO, James Tanner will manage operations and fortify relationships with A/V specialty dealers.
