Breakthrough 1.5 Petabyte Spintronics 3.5 Disk Drive
In the past we have only been able to orientate the direction a field of electrons move around a molecule like present day disk drive technology.
But by being able to rotate or spin the individual electrons that makeup or surround the molecule a much higher amplitude signal can be read by a read device.
An analogy would be our solar system with ALL the planets going around the Sun in a clockwise rotation direction.
Spintronics would be the effect of adding the spinning of the planets and their moons in a determined direction along with their clockwise rotation around the Sun.
Normally all the electrons could spin randomly working against the best electrical signal. The electrons are also capable of spinning in both directions a once.
By having uniform in sync spinning electrons this will allow a whole new field of science and electronics to emerge. With the ability to control electron spin we will see much smaller electronic devices on the market in the future.
One field is optical spintronics following Faradays laws. Because the potential data capacity is so large along with a very high data transfer rate. There will be NO need for expensive compression software like MPEG and others, and NO need to backup data unless you feel you have too.
Electrons have electro magnetic properties whose electron movement is called electric current that can be measured by the abundance of or lack of electrons in the ferroelectric nucleus called voltage or static charge.
Ferroelectric spintronics is the new method of using electric fields and photons to alter properties of ferroelectrics molecules for data manipulation by changing the internal geometry of ferroelectric atoms.
For example, when charge carriers like electrons are accelerated (as opposed to moving at constant velocity), a fluctuating magnetic field is produced. This generates a fluctuating electric field, known as a space charge field, which in turn produces another varying magnetic field.
Generating a perfect spin current by an electric field and UV photons in a high-k dipole dielectric material like a ferroelectrics molecule could then be made reversible, have non-dissipative of power, and not suffer from leakage current lost over time.
Thomas believes that intraband / outerband resonant absorption by circularly polarized UV photons leads to spin polarization of electrons. Then it is possible to say an “Atomic Quantum Switch” carries electro-static field, electro-magnetic field, and spin orientation that can be made to represent non-volatile 0’s and 1’s.
Double sided disk having 1.2 Petabytes of storage can be produced by separating the ferroelectric molecular coating layer by a plastic, metal, glass, or ceramic substrate.
Link: Colossal Storage Corporation http://colossalstorage.net
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
