Earbuds & In-Ear Headphones
Bowers & Wilkins Unveils PI7 S2 And PI5 S2 True Wireless ANC Earphones for 2023
The updated Bowers & Wilkins Pi7 S2 and Pi5 S2 True Wireless Earphones featured longer battery life, upgraded drivers, and superior sound quality.
Bowers & Wilkins Pi7 S2 Wireless Earbuds Midnight Blue
In April 2021, Bowers & Wilkins announced the Pi7 and Pi5 noise-canceling earphones. This was the first time B&W had entered the TWS (True Wireless Stereo) earphone market.
Building on the foundation of those models, B&W has announced new upgraded versions, the Pi7 S2 and Pi5 S2 that are intended to replace their well-received predecessors.
Bowers & Wilkins Pi7 S2 Wireless Earbuds on man lifestyle
What Both Models Feature
Although a lot remains the same, the Pi7 S2 and Pi5 S2 provide some subtle improvements over the Pi7 and Pi5.
Improved Wireless Connectivity: The Pi7 S2 and Pi5 S2 incorporate upgraded wireless connectivity with a new antenna design that supports increased Bluetooth range (up to 25m).
Improved Battery Life: Both new models provide up to five hours of listening time before needing to be recharged. Also, the 15-minute quick charge function provides an additional two hours of listening time. In addition, the charging cases provide additional battery life (16 hours for Pi7 S2 and 19 hours for the Pi5 S2).
Music App: Pi7 S2 and Pi5 S2 are the latest earphones to be fully integrated with the Bowers & Wilkins Music App. The app provides a seamless user experience that includes set-up, the configuration of noise cancellation modes, wear sensor adjustment, and a range of additional audio settings. The app also supports hi-res streaming direct from your mobile device via Qobuz, TIDAL, Deezer, and other select services. The Bowers & Wilkins Music App also offers additional user adjustments.
Bowers & Wilkins Music App Screenshots
One Button Control: Both models include an easy-to-use one-button user interface. The button allows listeners to perform multiple tasks.
Voice Assistance: In addition to one button control, these earphones also provide Siri or Google Assistant voice support, depending on the connected device.
Features on the Pi7 S2
Bowers & Wilkins Pi7 S2 Wireless Earbuds Satin Black
The Pi7 S2 continues to offer Wireless Audio Retransmission, which was introduced in the original Pi7. This enabled users to connect to an external audio source – such as an in-flight entertainment system – and then retransmit audio wirelessly from that source to the earbuds, via the Smart Charging Case.
The Pi7 S2 also continues to provide Qualcomm® aptX™ Adaptive. This allows Hi-res audio to be transmitted from compatible streaming services and devices. 24-bit/48kHz wireless transmission between each earbud is provided.
Pi7 S2 features 9.2mm drive units, joined by a high-frequency “balanced armature” driver, with each of the four drive units (2 for each earbud) actively driven by its own amplifier.
The Pi7 S2 also offers Adaptive Noise Cancellation to automatically monitor, analyze and adapt to its surroundings. That ANC system incorporates six microphones (3 on each earbud). In addition, to supporting ANC, the microphones optimize phone call sound quality.
ModelPi7 S2Pi7
Core FeaturesTrue Wireless Technology, True 24-bit Audio Connection, 2-way Drive Design, High-Performance DSP, Adaptive Noise Canceling, Audio RetransmissionTrue Wireless Technology, True 24-bit Audio Connection, Auto ANC, Audio Retransmission
Wearing StyleIn-earIn-ear
Bluetooth CodecsaptX Adaptive, aptX HD, aptX Classic, AAC, SBCaptX Adaptive, aptX HD, aptX Low Latency, aptX Classic, AAC, SBC
Bluetooth ProfilesA2DP, AVRCP, HFP, HSP, BLE GATTA2DP, AVRCP, HFP, HSP, BLE GATT
Frequency Band (Transmitter)2402 to 2480 MHz2402 to 2480 MHz
Frequency Band (Receiver)2402 to 2480 MHz2402 to 2480 MHz
RF Power Output<10.0 dBm<10.0 dBm
Drive Units 9.2 mm Dynamic Drive Units with Balanced Armature9.2 mm Dynamic Drive Units
Microphone3 per earbud3 per earbud
Battery TypeLithium-ionLithium Ion
Battery LifeUp to 5 hours with ANC Off and 16 hours from Charging CaseUp to 4 hours (Bluetooth)
Fast ChargeYes (15 min = 2 hours)Yes (15 min = 2 hours)
USB-C ChargingYesYes
Wireless ChargingYesYes
Waterproof (Earbuds only)IP54IP54
AccessoriesUSB-C Charging Cable, 3.5mm to USB-C audio cable, Eartips (s,m.l)USB-C Charging Cable, 3.5mm to USB-C audio cable, Eartips (s,l)
Charging Case Dimensions (WDH)61 x 28 x 56 mmN/A
Weight7 g (each earbud), 47 g (charging case)7 g (each earbud), 61 g (charging case)
Features on Pi5 S2
Bowers & Wilkins Pi5 S2 Wireless Earbuds Cloud Grey
Although the Pi7 S2 is the flagship, the Pi5 S2 also continues to offer great audio performance with TWS technology and a 9.2 mm driver in each earbud.
The Pi5 S2 supports CD-quality playback with aptX wireless transmission of music from an aptX-compatible mobile device. Pi5 S2 provides user-selectable noise-canceling plus ambient pass-through modes, as well as 2 built-in microphones per earbud for ANC and phone calls.
Model Pi5 S2 Pi5
Core FeaturesTrue Wireless TechnologyTrue Wireless Technology, Auto ANC
Bluetooth Codecsapt X, AAC, SBCapt X, AAC, SBC
Bluetooth ProfilesA2DP, AVRCP, HFP, HSPB, LE GATTA2DP, AVRCP, HFP, HSP, BLE GATT
Drive Units 9..2 mm Dynamic Drive Units with Balanced Armature9..2 mm Dynamic Drive Units
MicrophoneTwo per EarbudTwo per earbud
Battery TypeLithium-ionLithium-ion
Waterproof (Earbuds only)IP54 IP54
Weight6 g (each earbud), 47 g (charging case)7 g (each earbud), 47 g (charging case)
Bowers & Wilkins Pi7 S2 Wireless Earbuds Midnight Blue with Case
Availability & Pricing
The Pi7 S2 and Pi5 S2 earbuds are available from bowerswilkins.com and select retailers.
Pi7 S2: Satin Black, Canvas White, and Midnight Blue for $399.
Pi5 S2: Cloud Grey, Storm Grey, Spring Lilac, and Sage Green for $299.
Tip: The current price for the previous Pi7 ($399) and Pi5 ($149) respectively, but stock is low.
Bowers & Wilkins Pi7 S2 Wireless Charging Case midnight blue
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
