Bowers & Wilkins Panorama 2 Sound Bar
Bowers & Wilkins introduced a high-performance soundbar that dramatically boosts the audio performance of TV viewing, without the need to fill your living room with speakers. The new Panorama 2 is simple to connect and operate with HDMI, a new proximity-sensing control panel and an enhanced user interface. It offers the same great design and premium build quality as the original, with improved acoustic performance.
Panorama 2 features completely new Bowers & Wilkins engineered drive units, which deliver a dramatically enhanced acoustic performance. The new low frequency drivers have improved linearity for greater dynamic performance and lower resonance for deeper extension. The midrange drive units have wider dispersion characteristics, which helps to improve the virtual surround performance. The tweeter has been improved, too, for smoother integration with the midrange. The overall result is significantly improved acoustics on a product that already set the standard for audio performance from a soundbar.
Bowers & Wilkins Panorama 2 - rear
Of the nine drive units housed within Panorama 2’s sleek and rigid casework, five are utilized in the active centre speaker: two bass woofers, two midrange drivers and an aluminum dome tweeter featuring Bowers & Wilkins Nautilus tube-loaded technology. The other four drive units provide the rest of the sound, and each one is located within its own enclosure to maintain a purity of performance. All the drive units are powered by six class D amplifiers, providing a combined power output of 175 Watts.
This combination of bespoke drive unit technology, the latest in digital amplification and Digital Signal Processing (DSP) allows Panorama 2 to not only boost the quality of your TV to unprecedented levels, it also provides users with an immersive surround performance from a single speaker. The wide ‘sweet spot’, allows lots of people to experience the surround sound effects together, making it the ideal family entertainment system. For many people Panorama 2 will sound amazing on its own, however it’s simple to add a subwoofer such as Bowers & Wilkins PV1D, for an even further enhanced experience.
Bowers & Wilkins Panorama 2 - ports
Panorama 2 also has improved connection options, with the introduction of the latest HDMI connectivity. The three HDMI inputs and single HDMI output allows Panorama 2 to serve as the hub of your home entertainment system. So you can boost the audio performance not only of broadcast television, but also Blu-ray movie and games.
Panorama 2 retains the original’s aesthetic, and in terms of design and dimensions it is almost identical. However, it is now even easier to use thanks to a new proximity-sensing control panel and more intuitive On Screen Display (OSD). When Panorama 2 is operating the display is completely black, but when the user’s hand gets close, it slowly illuminates, allowing the user to control Panorama 2 directly. Panorama 2 is set up and configured through the OSD, and the menu system is designed to be so simple it can be used straight out of the box, without having to read the manual.
Bowers & Wilkins Panorama 2 in room
Bowers & Wilkins Panorama 2 - display
[youtube id=”IEs85rpHEjs” width=”610″ height=”373″]
Price and Availability
Bowers & Wilkins Panorama 2 is available now for $2,200.
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
