Bowers & Wilkins Unveils Most Powerful Subwoofer Yet
Bowers & Wilkins DB1D Subwoofer White
Does anyone need a subwoofer $4500 subwoofer?  Bowers & Wilkins thinks so, and has just unveiled their most powerful and best sounding active subwoofer to date.  The new flagship model is called the DB1D (12-inch), followed by the mid-sized DB2D (10-inch) and compact DB3D (8-inch), which each shave a grand off the price for each step down in size.
All three models have plenty of power,  dual-opposed drive units and incredibly rigid cabinets for dramatically reduced distortion for deep, agile bass.  Each model uses Aerofoil cones identical to those found in the B&W’s 800 Series Diamond loudspeakers. These light, ultra-stiff transducers resist bending and flexing far longer than conventional cones, delivering controlled bass with outstanding precision. The cone on the DB2D is the same as the 800 D3, while the DB1D features a massive 12-inch driver – the company’s largest Aerofoil cone to date.
The DB1D is also the most powerful active subwoofer Bowers & Wilkins has ever made; its 2,000 watt amplifier provides exceptional reserves of drive and authority. With their 1000 Watt amplifiers, the DB2D and DB3D mirror this capability in more compact forms.
All three DB Series subwoofers deploy two bass cones arranged in an opposed, balanced configuration. This technology was originally developed for the iconic PV1 subwoofer, and was also put to great use on the DB-1. Using this array greatly reduces cabinet vibration and ensures a cleaner, more precise sound. The company says the result is fantastic, coloration-free bass.
But all this power and precision is nothing without control, and thanks to an all-new digital pre-amplifier the DB Series subwoofers’ muscular sound is always delivered at optimum levels. Unique Bowers & Wilkins developed DSP such as Dynamic EQ and Room EQ ensure precision performance in every space.
The DB Series is incredibly simple to configure and use thanks to a dedicated mobile App. The App includes positioning guides, set-up and troubleshooting and can be used to provide control over both output and audio preset modes. The App is available for iOS and Android devices and no separate microphone kit required.
The new DB Series subwoofers are engineered to be flexible when it comes to connecting them to other equipment. They are obvious partners for the flagship 800 Series Diamond loudspeakers, but can easily be used with the CM Series or other loudspeakers. All three models will be available in a choice of three finishes: Gloss Black, Satin White and Rosenut.
Price & Availability
  • DB1D will be available May 2017 priced $4,500
  • DB2D will be available May 2017 priced $3,500
  • DB3D will be available May 2017 priced $2,500
Comparison & Specifications
DB1D DB2D DB3D
MSRP $4500 $3500 $2500
Drive units 2 x 300mm 2 x 250mm 2 x 200mm
(12in) (10in) (8in)
Max power output 2000W 1000W 1000W
Class D Hypex amplifier
Rating power consumption 360W 195W 195W
Signal to noise ratio 92dB 82db 82db
Features
Aerofoil-cone drive units in a balanced con guration Digital preampli er with Dynamic EQ, App-based set-up and BT-LE control
Frequency range (-6dB)
8.5Hz – 500Hz
Frequency Response -3dB (centred on level at 100Hz)
10Hz – 350Hz
Standby power consumption
<0.5W
Input impedance
XLR 20kOhm
RCA 10kOhm
Inputs
2 x XLR
2 x RCA
2 x 3.5mm 12V trigger RS-232 — 9-pin D connector
Dimensions
Height 460mm (18.1in) 430mm (16.9in) 360mm (14.1in)
Width 429mm (16.9in) 377mm (14.8in) 320mm (12.6in)
Depth 410mm (16.1in) 360mm (14.2in) 300mm (11.8in)
Net weight 43kg 36kg 25kg
Cabinet finish
Gloss Black (with black grilles) Rosenut (with black grilles) Satin White (with grey grilles)
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
From budget-friendly upgrades to room-shaking reference bass, these subwoofer picks deliver accurate low-end performance, smart features, and real value at every price tier.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Find out everything the HEOS app can do to simplify and manage a whole-home audio system with Denon and Marantz gear.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
