Bowers & Wilkins CM Series (S2) Loudspeakers
Bowers & Wilkins CM9 S2 Home Theater Speaker System
Bowers & Wilkins announced a new CM Series (S2) line of home loudspeakers, priced from $1,100 to $4,000 a pair. The entire line now includes a Decoupled Double Dome tweeter, while the CM10 S2 and the completely new CM6 S2 boast tweeter-on-top technology for an even more engaging performance.
Bowers & Wilkins Double Dome tweeters use a thin aluminum dome surrounded by a thicker aluminum ring for the perfect combination of lightness and rigidity, helping prevent audible distortion. The result is stunning clarity and tonal purity. In the new CM Series this advanced tweeter is also decoupled – using a ring of gel cushioning to physically separate the assembly from the cabinet – to improve dispersion and imaging for an even more natural, spacious treble.
The CM10 S2 and the new CM6 S2 also benefit from a tweeter-on-top design – a feature shared with our most advanced reference speaker range, the 800 Series Diamond. Isolating the tweeter in this way aids imaging and dispersion, creating a more lifelike sound and a better sense of space.
These tweeter advances are just the first of many improvements; the new CM Series has been redesigned to deliver vastly improved audiophile-standard performance across the board. New crossovers use respected Mundorf capacitors throughout while Anti-Resonance dustcaps are employed across all bass/midrange drive units for smoother response and lower coloration. These improvements augment existing CM Series technologies such as FST midrange drive units in the CM8 S2, CM9 S2 and CM Centre 2 S2 plus, in the flagship CM10 S2, the additional clarity of a decoupled FST assembly.
The new CM Series also look more beautiful than ever before. They retain the high-quality, real wood cabinets for which the range is renowned, but visible fixings have been removed for a cleaner, more subtle look. Yet even these visual improvements lead to acoustic benefits, as the incredibly solid cabinets and fixingless fascias help improve sound quality. The new, acoustically optimized and protective circular tweeter grilles further enhance the look of the new CM Series, while also protecting the tweeter.
Sitting pretty between the studio-quality speakers of the Bowers & Wilkins 800 Series Diamond and the surprisingly affordable new 600 Series, the new CM Series delivers stunning audiophile sound quality and subtle, stylish design perfect for home audio. The new CM Series truly is beautiful sound.
Bowers & Wilkins CM6 S2 & CM10 S2 Loudspeakers
The CM10 S2 (picture above, right) remains the flagship floorstanding speaker in the range, and has been brought visually into line with the rest of the new models. As well as a Decoupled Double Dome tweeter on top, physically removed from the main cabinet for vastly improved audio performance without distortion – a technique taken from the tweeters in Bowers & Wilkins 800 Series Diamond – the CM10 S2 features three powerful 165mm bass drivers and a decoupled FST midrange driver.
Joining the CM10 S2 with a Decoupled Double Dome tweeter-on-top design is the completely new CM6 S2 (pictured above, left). It features a 165mm bass/midrange driver, with the overall result being superb imaging and spaciousness for a standmount speaker. It is the first standmount CM Series speaker to benefit from tweeter-on-top technology.
The CM9 S2 and CM8 S2 are the two remaining floorstanding speakers in the range. Both feature Decoupled Double Dome tweeters, FST midrange drivers and two bass drivers. The new CM8 is designed with a slimmer profile to fit a wider range of room sizes and configurations, while still delivering amazing clarity, detail and realism.
The CM5 S2 and CM1 S2 are the range’s two other standmount speakers. Both models employ new Decoupled Double Dome tweeter technology plus a host of other engineering advances, making for compact and discreet speakers that still deliver ample power plus pin-sharp precision.
The CM Centre S2 and CM Centre 2 S2 also use Decoupled Double Dome tweeters while the CM Centre 2 S2 benefits from an FST midrange driver plus a pair of symmetrically arranged bass drivers to deliver superb centre channel performance. This makes the new CM Series ideal not just for stereo music but also for home cinema use.
The ASW10CM S2 subwoofer features a 10inch drive unit paper/Kevlar® driver driven by a highly efficient 500W audiophile standard Class D amplifier and switch mode power supply.
Completing the range is the new FS-CM S2 stand, with improved finish and design detailing to not only provide a supremely stable platform for the CM1 S2, CM5 S2 or CM6 S2 but also a perfect visual counterpart for the new models’ beautiful design.
Price and Availability
All new CM Series speakers are available in Gloss Black, Rosenut and Satin White finishes, except the ASW10CM S2, which is available in Gloss Black and Satin White. The FS-CM stand is available in Black and Silver finishes.
The new CM Series is available from September 2014
  • The new CM1 is priced $1100 per pair
  • The new CM5 is priced $1600 per pair
  • The new CM6 is priced $2000 per pair
  • The new CM8 is priced $2400 per pair
  • The new CM9 is priced $3200 per pair
  • The CM10 is priced $4000 per pair
  • The new CM Centre is priced $700 each
  • The new CM Centre 2 is priced $1250 each
  • The new ASW10CM S2 $1500 each
  • The new FS-CM stand is priced $500 per pair
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
