Earbuds & In-Ear Headphones
Bowers & Wilkins C5 In-Ear Headphones
Bowers & Wilkins announced the C5 in-ear, noise-isolating headphones. The innovative Secure Loop design keeps the C5 comfortably in place, and aids fit and performance. Plus the proprietary Micro Porous Filter enables the C5 to produce a wonderfully open, natural performance, perfect for longer listening sessions.
The Micro Porous Filter acts as a diffuser, enabling C5 to deliver pristine, natural audio, while also providing a more spacious performance than previously possible from in-ear headphones. It also has the advantage of limiting noise bleed, and together with the noise-isolating properties of the sealed fit, this allows users to lose themselves in flawless audio.
Almost as vital as performance in the in-ear headphone arena is comfort and quality of fit. C5 addresses this with the introduction of the proprietary Secure Loop design, an ingenious innovation where a cushioned loop fixes quickly and comfortably in the inner ridge of the user’s ear. This solution holds C5 in place for improved sound, and also makes it ideal for use on the move and during activities. The Secure Loop is infinitely adjustable, so it works perfectly with anyone’s ears.
Adding to this sense of comfort is C5’s Tungsten Balanced design. Here, high-mass material is located closer to the user’s ear, for an improved seal for better sound and noise isolation. Elsewhere C5 is crafted from high-grade aluminum for a premium-quality finish.
C5 comes supplied with a Made For iPhone compatible cable, which is ideal for making calls on the move, and a quilted pouch for easy storage.
Price and Availability
The B&W C5 is will be available August 2011 for $179.95 (U.S. & Canada).
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
