Bowers & Wilkins AM-1 Outdoor Speakers
Bowers & Wilkins AM-1 Outdoor Speaker - White
Durable, weatherproof loudspeaker, which avoids the acoustic compromises commonly associated with all-weather speakers
Bowers & Wilkins announced the new AM-1 Architectural Monitor, a weatherproof loudspeaker that offers a unique combination of high-quality sound, durability and supreme flexibility. AM-1 is suitable for installation in a wide range of outdoor and indoor applications.
Articulate, exciting and powerful, AM-1 avoids the compromises commonly associated with all-weather monitors, and delivers all the performance expected of a Bowers & Wilkins loudspeaker. A two-way design, it features an inverted drive unit configuration, with the AM-1’s 1inch (25mm) aluminum-dome tweeter mounted below rather than above a 5inch (130mm) glass-fiber bass/midrange driver. This ensures optimal dispersion of sound when the speaker is mounted high on the wall.
Bowers & Wilkins AM-1 Outdoor Speaker - Cutout
AM-1’s low-frequency output is bolstered by the use of a rear-mounted auxiliary bass radiator (ABR). Used instead of a conventional bass reflex port, the ABR endows AM-1 with exceptional bass response for a cabinet of its size. Unlike a port, it also provides AM-1’s cabinet with a continual seal against the elements. This combination of advanced drive units, unique configuration and classically simple crossover components combines to create a loudspeaker as musical as it is flexible.
Bowers & Wilkins AM-1 Outdoor Speaker - VerticalAnd flexible it most definitely is. AM-1 has been carefully designed to be easy to install. Its elegant cast aluminum wall bracket incorporates an ingenious one-plug mounting system. Designed to be positioned in either landscape or portrait mode when mounting, extra flexibility is offered by AM-1’s ability to be rotated through 110 degrees from center in both directions.
Its minimal projection out from a wall also adds to its appeal. So, while AM-1 has obvious applications such as providing high-quality audio around gardens, patios and around swimming pools, its sleek design will also find favor indoors. Venues such as bars, restaurants and other communal areas will benefit from AM-1’s winning combination of premium sound quality, discreet styling, flexibility and durable construction.
AM-1 combines a rustproof aluminum grille with a rigid cabinet composed of glass-filled plastics, ensuring class-leading resistance to extremes of dust, moisture and UV exposure. It has also undergone rigorous, continuous testing in an accelerated salt-spray chamber, plus outdoor UV accelerated life tests to ensure its parts don’t fade or discolor.
am1-topBowers & Wilkins AM-1 Outdoor Speaker - side
Price and Availability
Bowers & Wilkins AM-1 will be available March 2013 for $300.00 each (USD) in in white or black finishes.
6 Comments
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
