Loudspeakers
Bowers & Wilkins 600 Series Loudspeakers
Bowers & Wilkins 683 Speaker System
Bowers & Wilkins just announced six new and more affordable 600 Series loudspeakers for stereo hi-fi or home theater, which the company claims vastly improves upon on every facet of its predecessors. The new line-up consists of two floorstanders, two bookshelf size speakers, and two center-channel models.
The new 600 Series utilizes Bowers & Wilkins engineering solutions from other ranges – Double Dome Tweeters derived from the CM10 speaker extend the first breakup frequency to 38kHz, Anti-Resonance Plugs for mid/bass drive units first seen in the PM-1 lowers bass distortion and improves dynamics and, Bowers & Wilkins’ iconic Kevlar cones, which are said to provide smooth, articulate midrange. Added to these proven technologies are new advances developed specifically for the new 600 Series, including new Dual Layer aluminum bass drivers and new tweeter decoupling technology.
The Decoupled Double Dome tweeter comprises two separate aluminum domes, the second with its center portion cut out and glued to the rear face of the first dome to create a remarkable blend of lightness and rigidity. The entire tweeter assembly is then decoupled, being physically separated from the cabinet by a cushioning gel ring in much the same way as our outboard tweeters. Harmful resonances are neither transferred from the baffle to the tweeter or the tweeter to the baffle. The resulting Decoupled Double Dome tweeter has stunning clarity and tonal purity plus outstanding imaging and dispersion. The new models sound bigger with less dynamic compression – credit much of that to the new tweeter design. B&W has also fitted the new design with an optimized steel mesh grille to prevent accidental or malicious damage in a decorative brushed aluminum plate with a diamond cut logo.
B&W 683 Floorstanding Loudspeakers
B&W 683
The 683 is the largest speaker in the new 600 Series – a floorstander designed to deliver outstanding power, accuracy and musicality. The 683 features the new Decoupled Double Dome tweeter, an FST midrange driver and new Dual Layer aluminum bass drivers. This new Dual Layer design sees an aluminum bass cone reinforced around its periphery with a second layer of aluminum, for a more effectively damped cone and higher break-up frequency. The result is even richer, distortion-free bass. With exceptional performance across the frequency range, the new 683 fuses serious stereo and home cinema sound with amazing value for a speaker of this caliber.
B&W 684 Floorstanding Loudspeakers
B&W 684
The new 684 floorstander is now slimmer than ever, yet still offers an amazing combination of serious power, clarity and unbeatable value. That’s because of improved Kevlar bass/midrange drive units and the Decoupled Double Dome tweeter. 5” mid/bass drivers replace the 6.5” drivers of the current 684, affording a decor-friendly appearance, yet Bowers & Wilkins engineers have improved audio performance by using the Anti-Resonance Plugs in the drivers to deliver smoother response and lower distortion when driven hard. The 684 is also a 2-way design compared to the 2.5 way of the previous model. The smaller drivers have broader off axis response at higher frequencies, allowing the use of a simpler crossover. The result is room-filling sound without a room-filling speaker cabinet.
B&W 685 Bookshelf Loudspeakers
B&W 685
The versatile new 685 is at home on a stand or bookshelf. Perfectly sized for most rooms, it combines new Decoupled Double Dome tweeters, Kevlar cones and Anti-Resonance Plugs with all the value for which the 600 Series is renowned. The Decoupled Double Dome tweeter found throughout the new 600 Series builds on technology developed for the award-winning CM10. The new 685 is destined to follow in the footsteps of its highly acclaimed predecessors, the 601 and the outgoing 685, and will be recognized as THE definitive affordable compact loudspeaker – just as its predecessors were in their time.
Bowers & Wilkins 686 Bookshelf Speakers
B&W 686
The new 686, sized at just 6.3” wide x 12.4” high x 9” deep, is the most compact speaker in the new 600 Series, but still includes a new Decoupled Double Dome tweeter and improved Kevlar driver with Anti-Resonance Plug. Its main 5-inch driver features a 25mm voice coil for higher sensitivity, and it now has a front rather than rear-firing Flowport, making it ideal for placement near a wall or in a bookshelf. The 686 features a built-in bracket for easy wall mounting, bookshelf or table-top placement.
Bowers & Wilkins HTM61 Center Channel Speaker
B&W HTM61
HTM61 has probably seen greater change than any other in the range. The outgoing model, in an effort to minimize baffle area while still offering a full 3-way system, had only a single bass driver and an asymmetrical horizontal dispersion pattern around the upper crossover frequency. The new model takes a similar design philosophy to the CM Center 2 and has grown considerably as a result. Placing the tweeter directly above the 4” FST midrange driver guarantees a symmetrical dispersion and the extra bass driver matches the power output of the 683, with which this center speaker should be used in a home theater installation.
B&W HTM62 Center Speaker
B&W HTM62
HTM62, the smaller of the two center speakers, carries over the twin 5” bass/midrange with central tweeter concept of the outgoing model. The cabinet height has been reduced in the same way that the 686 width has decreased, but in order to keep the same internal volume without increasing depth, the cabinet width has increased a little. However, both center speakers retain rear-facing ports in order to minimize cabinet width. The speaker may be considered as a 684 on its side, with the tweeter moved to a position between the bass/midrange drivers to guarantee a symmetrical horizontal dispersion. Typically, it would be included into any 600 Series home theatre system that did not feature the 683 at front left and right.
Price and Availability
The Bowers & Wilkins 600 Series will available in a Black Ash finish only from March 2013.
  • The 683 is priced $1,650 per pair.
  • The 684 is priced $1,150 per pair.
  • The 685 is priced $700 per pair.
  • The 686 is priced $550 per pair.
  • The HTM61 is priced $750 each.
  • The HTM62 is priced $450 each.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Hands-on review of the Bowers & Wilkins Pi6 In-ear True Wireless Earbuds covers sound quality, ANC performance and more.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
